Hi
I did followed the instractions on:
How to set up Qt Creator to cross compile for embedded Linux | Toradex Developer Center
And wanted to compile and deploy may first (small) example (Qmainwindow in a QApplication).
What goes is:
Device is connected and test show the device
Qmake create a makefile
But then i have several errors by compiling the makefiles.
I have added the output of qtcreator and also added the generated makefile.
What is here wrong?
I saw that qmake is on another path as in description:
link text
Ok, i forgot the last step and set Qmake specs under “Kits” to:
/usr/local/oecore-x86_64/sysroots/armv7at2hf-neon-angstrom-linux-gnueabi/usr/lib/qt5/mkspecs/linux-oe-g++
But now i can’t deploy (see screenshot atached)
