I just tried a ‘HelloWorld’, yes, the SDK is installed and the right Project template choosen, but the Launch Fails. I read through some Posts and it seems, that there is no netcf included in the OS Image.
I also found the cab file to install netcf3.9 on my WEC 2013 devive, but how is this done?
I copy the file to the Flash disk and try to run, cause there is nothing like an installer. Only a program remover was found …
I also found some Posts, were peope discuss how to make the Installation of the netcf permanent.
In my former Project I build an OS Image including netcf, so this wasn’t a Problem.
I understand, that Toradex choos another way for optimizing size of the Image, but now, I Need an detailed description how to install netcf3.9 permanentely.
Thanks a lot.
With best regards
Gerhard
