Hi there,
I am trying to test the effect of building my application with static links to the Qt library.
For that I build Qt statically using the following configuration:
~/Qt/5.9.6/Src/configure -prefix /usr/local/qt5_static -extprefix ~/Qt/5.9.6/toradex_static_bin -device linux-imx6-g++ -device-option CROSS_COMPILE=/usr/local/oecore-x86_64/sysroots/x86_64-angstromsdk-linux/usr/bin/arm-angstrom-linux-gnueabi/arm-angstrom-linux-gnueabi- -sysroot /usr/local/oecore-x86_64/sysroots/armv7at2hf-neon-angstrom-linux-gnueabi -skip qt3d -skip qtandroidextras -skip qtcanvas3d -skip qtcharts -skip qtconnectivity -skip qtdatavis3d -skip qtgamepad -skip qtlocation -skip qtmacextras -skip qtnetworkauth -skip qtpurchasing -skip qtremoteobjects -skip qtscxml -skip qtsensors -skip qtspeech -skip qtwebchannel -skip qtwebengine -skip qtwebsockets -skip qtwebview -skip qtwinextras -skip qtxmlpatterns -nomake examples -nomake tests -static -confirm-license -v
With a kit in Qt creator that links to the newly built Qt (5.9.6) I successfully compiled application. When I tried to run it it was first missing two shared libraries:
libtiff.so.5 and libpulse-mainloop-glib.so.0
I was able to resolve that by updating the opkg package manager and then installing the libtiff5 and the libpulse-mainloop-glib packages.
However, now I am stuck with the following error:
libtiff.so.5: version `LIBTIFF_4.0' not found
Is this a platform issue? Have I maybe some mistakes in the configuration? Has anybody experienced similar problems?
Thanks for any help in advance!
