Hello, I’ve got problem with launch browser on Apalis TK1 (on board Ixora V1.1A)
I have built tdk-reference-multimedia-image, as it is described in tutorial:
Build a Reference Image with Yocto Project/OpenEmbedded
I need to add browser to my image, which could serve Node.js in the future, so I have started from chromium.
I’ve added “IMAGE_INSTALL_append = < chromium-x11>” to conf/local.conf, cloned layers meta-browser and meta-clang (branch dunfell) to /layers directory and add them to conf/bblayers.conf
After this I built tdx- reference-multimedia-image again, with success. After boot into Tegra chromium packet is installed, but during run I’ve got this errors:
root@apalis-tk1-06737470:/# chromium --no-sandbox --disable-gpu --disable-software-rasterizer
[0126/122737.768869:FATAL:semaphore_posix.cc(99)] Check failed: . sem_timedwait: Invalid argument (22)
*** stack smashing detected ***: terminated
[1079:1111:0126/122738.005043:ERROR:bus.cc(393)] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are "tcp" and on UNIX "unix")
[1079:1111:0126/122738.005137:ERROR:bus.cc(393)] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are "tcp" and on UNIX "unix")
[1079:1079:0126/122738.045869:ERROR:cursor_loader.cc(114)] Failed to load a platform cursor of type kNull
[1079:1079:0126/122738.133692:ERROR:gpu_process_host.cc(967)] GPU process exited unexpectedly: exit_code=6
[1109:1121:0126/122738.231575:ERROR:ssl_client_socket_impl.cc(983)] handshake failed; returned -1, SSL error code 1, net_error -167
[1109:1121:0126/122738.238040:ERROR:ssl_client_socket_impl.cc(983)] handshake failed; returned -1, SSL error code 1, net_error -167
[1079:1079:0126/122738.240240:ERROR:gpu_process_host.cc(967)] GPU process exited unexpectedly: exit_code=6
[1079:1079:0126/122738.282339:ERROR:gpu_process_host.cc(967)] GPU process exited unexpectedly: exit_code=6
[1079:1079:0126/122738.282941:FATAL:gpu_data_manager_impl_private.cc(417)] GPU process isn't usable. Goodbye.
Trace/breakpoint trap
I also tried to launch fancybrowser from QtWebKit/QtWebEngine packet, but couldn’t manage it.
I know that Apalis TK1 is not good choice at this moment, but in few days I’m gonna need to do the same things on IM8X.
Have you got any advice how to add chromium, or other working web browser into image? Or maybe using reference multimedia image is not good idea, and I should build my own Linux distribution on Tegra?
