I am trying to flash the colibri iMX7 from a USB card with a customized image derived from the demo image (High performance, low power | Footprint for embedded computing).
When running ‘update’, the script stops just after reading zImage : size > volume size! Aborting!
Here is my log (at the end there is the result of mtdparts) :
Colibri iMX7 # run setupdate
Card did not respond to voltage select!
starting USB...
USB0: USB EHCI 1.00
scanning bus 0 for devices... 1 USB Device(s) found
USB1: USB EHCI 1.00
scanning bus 1 for devices... 3 USB Device(s) found
scanning usb for storage devices... 1 Storage Device(s) found
reading colibri_imx7/flash_blk.img
2707 bytes read in 30 ms (87.9 KiB/s)
## Executing script at 80800000
enter "run update" to update the entire module
Colibri iMX7 # run update
reading colibri_imx7/u-boot-nand.imx
598016 bytes read in 71 ms (8 MiB/s)
NAND erase.part: device 0 offset 0x80000, size 0x180000
Erasing at 0x80000 -- 8% complete.
Erasing at 0xa0000 -- 16% complete.
Erasing at 0xc0000 -- 25% complete.
Skipping bad block at 0x000e0000
Erasing at 0x100000 -- 41% complete.
Erasing at 0x120000 -- 50% complete.
Erasing at 0x140000 -- 58% complete.
Erasing at 0x160000 -- 66% complete.
Erasing at 0x180000 -- 75% complete.
Erasing at 0x1a0000 -- 83% complete.
Erasing at 0x1c0000 -- 91% complete.
Erasing at 0x1e0000 -- 100% complete.
OK
NAND write: device 0 offset 0x80000, size 0x92000
Skip bad block 0x000e0000
598016 bytes written: OK
NAND erase.part: device 0 offset 0x200000, size 0x180000
Erasing at 0x200000 -- 8% complete.
Erasing at 0x220000 -- 16% complete.
Erasing at 0x240000 -- 25% complete.
Erasing at 0x260000 -- 33% complete.
Erasing at 0x280000 -- 41% complete.
Erasing at 0x2a0000 -- 50% complete.
Erasing at 0x2c0000 -- 58% complete.
Erasing at 0x2e0000 -- 66% complete.
Erasing at 0x300000 -- 75% complete.
Erasing at 0x320000 -- 83% complete.
Erasing at 0x340000 -- 91% complete.
Erasing at 0x360000 -- 100% complete.
OK
NAND write: device 0 offset 0x200000, size 0x92000
ubi0: default fastmap pool size: 200
ubi0: default fastmap WL pool size: 100
ubi0: attaching mtd1
ubi0: attached by fastmap
ubi0: fastmap pool size: 200
ubi0: fastmap WL pool size: 100
ubi0: attached mtd1 (name "mtd=4", size 508 MiB)
ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
ubi0: good PEBs: 4055, bad PEBs: 9, corrupted PEBs: 0
ubi0: user volume: 4, internal volumes: 1, max. volumes count: 128
ubi0: max/mean erase counter: 6/2, WL threshold: 4096, image sequence number: 1800755034
ubi0: available PEBs: 0, total reserved PEBs: 4055, PEBs reserved for bad PEB handling: 71
reading colibri_imx7/zImage
8548312 bytes read in 680 ms (12 MiB/s)
Colibri iMX7 # mtdparts
device nand0 <gpmi-nand>, # parts = 5
#: namesizeoffsetmask_flags
0: mx7-bcb 0x000800000x000000000
1: u-boot1 0x001800000x000800001
2: u-boot2 0x001800000x002000001
3: u-boot-env 0x000800000x003800000
4: ubi 0x1fc000000x004000000
active partition: nand0,0 - (mx7-bcb) 0x00080000 @ 0x00000000
defaults:
mtdids : nand0=gpmi-nand
mtdparts: mtdparts=gpmi-nand:512k(mx7-bcb),1536k(u-boot1)ro,1536k(u-boot2)ro,512k(u-boot-env),-(ubi)
Can somebody help me ?
