my procedure for flashing a Linux image was the following on an iMX7D on Viola Board:
Download Easy Installer and extract onto micro SD card
Insert Sd card in the Viola Board and run the mmc-bootcmd to boot the Easy installer
Then copy the desired image onto a USB stick, insert it and flash with the previously booted Easy installer
Now I basically want to do the same on an iMX8DX on the same Viola Board. When I first received the module there was no Easy Installer per default, but the procedure that I described above still worked and I was able to start the Easy Installer and to flash a Torizon-Image.
But now (with new U-Boot and Linux flashed) the Easy Installer can´t be started from Sd card anymore (no changes to the card).
The following error appears:
U-Boot 2020.04-5.1.0+git.0a26a04408ca (Jan 01 1970 - 00:00:00 +0000)
CPU: NXP i.MX8QXP RevC A35 at 1200 MHz at 42C
DRAM: 1022 MiB
MMC: FSL_SDHC: 0, FSL_SDHC: 1
In: serial
Out: serial
Err: serial
Model: Toradex Colibri iMX8 DualX 1GB V1.0D, Serial# 06797313
BuildInfo:
- SCFW 732e719a, SECO-FW 376e3c15, IMX-MKIMAGE 6745ccdc, ATF
- U-Boot 2020.04-5.1.0+git.0a26a04408ca
flash target is MMC:0
Net: eth0: ethernet@5b040000 [PRIME]
Fastboot: Normal
Normal Boot
Colibri iMX8X # run bootcmd_mmc1
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1...
Found U-Boot script /boot.scr
2246 bytes read in 14 ms (156.3 KiB/s)
## Executing script at 83200000
This script is only meant for Apalis iMX8 / Apalis iMX8X / Colibri iMX8X
and Verdin iMX8MM
SCRIPT FAILED: continuing...
2246 bytes read in 13 ms (168 KiB/s)
and Verdin iMX8MM
So it seems that a wrong board name is used, because the board name that was set in u-boot is “colibri-imx8x” but that does not get checked in the script. If I just change the name to “colibri-imx8qxp” then I get the following error:
Colibri iMX8X # setenv board colibri-imx8qxp
Scanning mmc 1:1...
** Reading file would overwrite reserved memory **
So there seems to be an incompatibility with u-boot and the Easy installer… Does someone have an idea how i can start the Easy installer again?
Additional info:
Booting from the internal Flash or using a Yocto-build on Sd-card still works as expected.
When I change the address so that the itb file can be loaded (to avoid the restricted memory) then I get:
Colibri iMX8X # env set bootcmd_tezi 'load ${devtype} ${devnum}:${distro_bootpart} ${kernel_addr_r} ${tezi_image}'
Colibri iMX8X # env set bootcmd_run 'bootm ${kernel_addr_r}#config@freescale_${fdtfile}'
37580496 bytes read in 1629 ms (22 MiB/s)
Wrong Image Format for bootm command
ERROR: can't get kernel image!
Colibri iMX8X #
I was able to extract the Kernel, squashfs and device tree from the .itb file and load them manually to different addresses. The kernel image seems to be accepted with booti-command, but then the the squashfs seems to be in the wrong format. (Or isn´t it a squashfs at all?) Here is the error:
Colibri iMX8X # booti $kernel_addr_r $loadaddr $fdt_addr_r Wrong Ramdisk Image Format
Ramdisk image is corrupt or invalid
Any idea how I can get the correct ramdisk format?
I was finally able to start the Easy Installer by extracting the kernel image, device tree and squashfs from the .itb-file, placing the latter on a seperate partition of a sd card and running the following commands in uboot:
In case of using the Viola, you need to follow the steps for “Other Carrier Boards” in the Recovery Mode section of your module.
The most important thing is to be sure to be using the USB OTG cable between the carrier board and your computer. Please connect this cable to a direct USB port on your computer, without using a USB HUB.
