Based on the documentation, torizoncore-builder build supports variable substitution in tcbuild. yaml.
Variables can be set through –set ASSIGNMENT command line option to torizoncore-builder build.
In my CI pipeline I don’t call torizoncore-builder build directly, but I leverage on tcb-build task as provided by Toradex.
How can I have variable substitution working in this case?
I mean, I can create env variable on the agent that runs the pipeline (and the task), but I can I pass these variables to torizoncore-builder?
Hello! Great question regarding variable substitution in the context of CI pipelines using the tcb-build task.
Currently, variable substitution in torizoncore-builder via the --set command-line option is documented only for direct invocation of torizoncore-builder build . As per the official documentation, you can substitute variables in your tcbuild.yaml like this:
output:
easy-installer:
local: torizon-core-docker-colibri-imx6-with-containers
name: "${IMAGE_NAME-Default image name}"
description: "${IMAGE_DESC?Please provide a description for this image}"
However, the tcb-build task is a higher-level automation (often in CI/CD tools or Torizon Cloud CI), and as of the published documentation, there’s no mention of a built-in mechanism to pass variable assignments directly through it (such as a --set equivalent).
Typical ways in such cases:
If tcb-build is a wrapper, check if it forwards any additional arguments to torizoncore-builder build . You could try passing --set arguments after a – (double dash) if your CI system supports it (e.g., tcb-build … – --set IMAGE_NAME=“My Image” … ), but confirm how your task interprets arguments.
Setting environment variables alone may not work for substitution unless specifically supported in the tcbuild.yaml or by tcb-build .
If tcb-build lacks direct support, a common workaround is to template your tcbuild.yaml as part of your pipeline, replacing variables via shell scripting or a configuration management tool before running tcb-build .
Summary:
As of the current documentation, there’s no explicit, documented support for passing variable assignments to the underlying torizoncore-builder build via the tcb-build task. You may need to use preprocessing on your pipeline agent to inject variables directly into your tcbuild.yaml .
You can find further information here in the documentation:
For the time-being I don’t believe there is a way or mechanism to do so with VSCode. One would probably need to manually edit the tcb-build task definition in the tasks.json and add the variable assignments to the build command.
This is what I did (as a workaround).
Can toradex consider a future improvement to handle this need is a “native” way (i.e., withotu having to manually edit tcb-build task)?
