I am using Apalis TK1 on Ixora V1.0A, and I want to stream real time video from an IP camera. I used to perform same task on my Jetson TK1 with following gstreamer pipeline.
gst-launch rtspsrc location=rtsp://IPaddressOfMyCamera/stream1 latency=500 ! gstrtpjitterbuffer ! rtphdepay ! nv_omx_h264dec ! 'video/x-nv-yuv' ! nvvidconv ! 'video/x-raw-gray, width=640, width=360' ! 'video/x-raw-yuv' ! plugin ! nvvidconv ! 'video/x-nv-yuv' ! nv_omx_hdmi_videosink
Since the pipelines with nvs are customized for nvidia, I could not use them on my Apalis. I tried to use following pipelines.
gst-launch-0.10 playbin2 uri=rtsp://${CAMIP}/stream1
I got the following lines(but no video)
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
Missing element: H.264 decoder
WARNING: from element /GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0: No decoder available for type 'video/x-h264, stream-format=(string)byte-stream, alignme.
Additional debug info:
../../../gst-plugins-base-0.10.36/gst/playback/gsturidecodebin.c(874): unknown_type_cb (): /GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0
ERROR: from element /GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0/GstDecodeBin2:decodebin20: Your GStreamer installation is missing a plug-in.
../../../gst-plugins-base-0.10.36/gst/playback/gstdecodebin2.c(3576): gst_decode_bin_expose (): /GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0/GstDecodeBin2::
no suitable plugins found
Execution ended after 2983308120 ns.
Setting pipeline to READY ...
Setting pipeline to NULL ...
Freeing pipeline ...
Then I tried the following pipeline.
gst-launch -v rtspsrc location=rtsp://IPaddressOfMyCamera/stream1 ! "application/x-rtp, media=video" ! decodebin2 ! ffmpegcolorspace ! xvimagesink
I got the following lines (but no video)
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:rtpbin0: latency = 2000
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:rtpbin0: buffer-mode = slave (1)
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstUDPSrc:udpsrc1: timeout = 5000000
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstUDPSrc:udpsrc1: timeout = 0
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:rtpbin0.GstGhostPad:send_rtcp_src_0: caps = application/x-rtcp
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:rtpbin0/GstRtpSession:rtpsession0.GstPad:send_rtcp_src: caps = application/x-rtcp
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstUDPSink:udpsink1.GstPad:sink: caps = application/x-rtcp
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:rtpbin0.GstGhostPad:send_rtcp_src_0.GstProxyPad:proxypad3: caps = application/x-rtcp
/GstPipeline:pipeline0/GstCapsFilter:capsfilter1: caps = application/x-rtp, media=(string)video
/GstPipeline:pipeline0/GstCapsFilter:capsfilter1.GstPad:src: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(1
/GstPipeline:pipeline0/GstCapsFilter:capsfilter1.GstPad:sink: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=1
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0.GstGhostPad:recv_rtp_src_0_759901269_96: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int1
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0.GstGhostPad:recv_rtp_src_0_759901269_96.GstProxyPad:proxypad5: caps = application/x-rtp, media=(string)video, payload=(i1
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:rtpbin0.GstGhostPad:recv_rtp_src_0_759901269_96.GstProxyPad:proxypad4: caps = application/x-rtp, media=(string1
/GstPipeline:pipeline0/GstDecodeBin2:decodebin20/GstTypeFindElement:typefind.GstPad:src: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate1
/GstPipeline:pipeline0/GstDecodeBin2:decodebin20/GstTypeFindElement:typefind.GstPad:sink: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rat1
/GstPipeline:pipeline0/GstDecodeBin2:decodebin20.GstGhostPad:sink: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-1
/GstPipeline:pipeline0/GstDecodeBin2:decodebin20.GstGhostPad:sink.GstProxyPad:proxypad0: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate1
/GstPipeline:pipeline0/GstDecodeBin2:decodebin20/GstRtpH264Depay:rtph264depay0.GstPad:src: caps = video/x-h264, stream-format=(string)byte-stream, alignment=(strinl
/GstPipeline:pipeline0/GstDecodeBin2:decodebin20/GstRtpH264Depay:rtph264depay0.GstPad:sink: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-r1
/GstPipeline:pipeline0/GstDecodeBin2:decodebin20/GstH264Parse:h264parse0.GstPad:src: caps = video/x-h264, stream-format=(string)byte-stream, alignment=(string)nal,e
/GstPipeline:pipeline0/GstDecodeBin2:decodebin20/GstH264Parse:h264parse0.GstPad:sink: caps = video/x-h264, stream-format=(string)byte-stream, alignment=(string)nal
ERROR: from element /GstPipeline:pipeline0/GstDecodeBin2:decodebin20: Your GStreamer installation is missing a plug-in.
../../../gst-plugins-base-0.10.36/gst/playback/gstdecodebin2.c(3576): gst_decode_bin_expose (): /GstPipeline:pipeline0/GstDecodeBin2:decodebin20:
Execution ended after 2919324649 ns.
/GstPipeline:pipeline0/GstDecodeBin2:decodebin20/GstCapsFilter:capsfilter2.GstPad:src: caps = video/x-h264, stream-format=(string)byte-stream, alignment=(string)nae
/GstPipeline:pipeline0/GstDecodeBin2:decodebin20/GstCapsFilter:capsfilter2.GstPad:sink: caps = video/x-h264, stream-format=(string)byte-stream, alignment=(string)ne
/GstPipeline:pipeline0/GstDecodeBin2:decodebin20/GstCapsFilter:capsfilter2.GstPad:src: caps = NULL
/GstPipeline:pipeline0/GstDecodeBin2:decodebin20/GstCapsFilter:capsfilter2.GstPad:sink: caps = NULL
/GstPipeline:pipeline0/GstDecodeBin2:decodebin20/GstH264Parse:h264parse0.GstPad:src: caps = NULL
/GstPipeline:pipeline0/GstDecodeBin2:decodebin20/GstH264Parse:h264parse0.GstPad:sink: caps = NULL
/GstPipeline:pipeline0/GstDecodeBin2:decodebin20/GstRtpH264Depay:rtph264depay0.GstPad:src: caps = NULL
/GstPipeline:pipeline0/GstDecodeBin2:decodebin20/GstRtpH264Depay:rtph264depay0.GstPad:sink: caps = NULL
/GstPipeline:pipeline0/GstDecodeBin2:decodebin20/GstTypeFindElement:typefind.GstPad:src: caps = NULL
/GstPipeline:pipeline0/GstDecodeBin2:decodebin20/GstTypeFindElement:typefind.GstPad:sink: caps = NULL
/GstPipeline:pipeline0/GstDecodeBin2:decodebin20.GstGhostPad:sink: caps = NULL
/GstPipeline:pipeline0/GstCapsFilter:capsfilter1.GstPad:src: caps = NULL
/GstPipeline:pipeline0/GstCapsFilter:capsfilter1.GstPad:sink: caps = NULL
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0.GstGhostPad:recv_rtp_src_0_759901269_96: caps = NULL
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:rtpbin0.GstGhostPad:recv_rtp_src_0_759901269_96: caps = NULL
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:rtpbin0.GstGhostPad:send_rtcp_src_0: caps = NULL
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:rtpbin0/GstRtpPtDemux:rtpptdemux0.GstPad:src_96: caps = NULL
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:rtpbin0/GstRtpSession:rtpsession0.GstPad:send_rtcp_src: caps = NULL
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstUDPSink:udpsink1.GstPad:sink: caps = NULL
Furthermore, I tried the following pipeline.
gst-launch rtspsrc location=rtsp://IPaddressOfMyCamera/stream1 latency=500 ! decodebin ! autovideosink
ERROR: from element /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstUDPSrc:udpsrc0: Internal data flow error.
../../../../gstreamer-0.10.36/libs/gst/base/gstbasesrc.c(2625): gst_base_src_loop (): /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstUDPSrc:udpsrc0:
streaming task paused, reason not-linked (-1)
Execution ended after 1211622416 ns.
Can someone help me or advise me a solid gstream pipeline to perform rtsp from an IP camera using Apalis TK1?
Best,
Kemal.
