My application uses RS485 for the physical layer.
I am able to send requests, but I rarely receive the associated responses. When my device receives any response, it does it sometimes 2 or 3 times and then causes a frame error.
I use the following communication parameters:
Baud rate = 19200
Parity = even
Data bits = 8
Stop bits = 1
The receiver I am using is communicating well with other devices.
I have read about the weak DMA-implementation and therefore deactivated it by using “setenv defargs ‘${defargs} fsl_lpuart.nodma=0’”. This does not solve the problem.
I suspect that the RTS timing control is not working properly.
hi @ustorts
Could you provide the version of the hardware and software of your module?
Which carrier Board are you using?
What is your device? Could you provide some Information about you use-case?
Which devices and which receiver are you using?
Why do you think this?
The carrier board is an own development, that uses the ST1480AB transceiver.
The kernel version is 4.4.39-dirty and the hardware Colibri VF61.
What changes have you done to the kernel? Could you provide your kernelconfig (.config)?
Could you please provide some help for this issue?
Hi @ustorts
Sorry that nobody answered that long.
@jaski.tx will try to reproduce your issue on Monday.
Philippe
The only change is the following.
CONFIG_RTC_DRV_PCF8563=m
link text
hi @ustorts
I am going to reproduce the issue. I just need some Information:
- Did you check this site and configured RS485 correctly?
- Could you provide a schematic of your RS485 connection to the module?
For disabling DMA, you could use this.
