RPMSG doesn't work on iMX8QXP after update to BSP 7.1
after upgrading from BSP 6.3 to 7.1, RPMSG stopped working on iMX8QXP, imx-rpmsg ends up “probe deferred” and no ttys open.
We’re using low level stuff from BSP (u-boot, SCU, ATF, etc.), kernel is based on the same commit as the BSP one, config is custom. Device tree is inspired by Toradex dtbs. Userspace is customized Debian.
RPMSG in dtb is configured in the same way as your hmp overlay (colibri-imx8x_hmp_overlay.dts « overlays - device-tree-overlays.git - Sources for Device Tree Overlays). From looking at the kernel prints it seems driver imx-rpmsg can’t find mailboxes provided by lsio_mu5. It looks like that message unit is not available/registered/turned on or something?
Weirdly in dmesg, there is error:
mu_a1: failed to power off resource 214 ret -22
The resource 214 is power domain of M4, I don’t what’s trying to turn it off and why. It just seems SCU refuses. I’m not sure if it’s related to my problem.
Someone was asking here:
I tried to check dtb according to it, but still it didn’t work and that pertains to remoteproc instead of rpmsg anyway (I’m presuming I’m still supposed to use rpmsg and not remoteproc node for this SoC).
Any ideas or solutions? For now I’m thinking looking at SCU serial port if something would clue me in, but it seems a bit of long shot.
Thanks and best regards,
Marek
Hello!
To ensure RPMsg operates correctly on your Colibri iMX8X, please follow these steps:
  1. Apply the Correct Device Tree Overlay: Make sure the Colibri iMX8X HMP overlay is applied. This overlay is crucial for configuring RPMsg on the iMX8X. You can find it in the device-tree-overlays repository here.
  2. Verify RPMsg Driver Registration: After applying the overlay and rebooting your system, check if the RPMsg driver is registered by running the following command:
    dmesg | grep -i rpmsg
    You should see a message indicating “imx rpmsg driver is registered.” More details can be found here.
  3. Ensure Proper Memory Allocation: The memory regions for RPMsg must be correctly allocated in the device tree. Here are the key memory addresses that need configuration:
    vdev0vring0: vdev0vring0@b8000000 {
        reg = <0 0xb8000000 0 0x8000>;
        no-map;
    vdev0vring1: vdev0vring1@b8008000 {
        reg = <0 0xb8008000 0 0x8000>;
        no-map;
    You can refer to the detailed guide here.
Regarding the specific error about resource 214 and MU5, this might indicate a conflict in the power domain configuration. This issue has been noted in community discussions, particularly with BSP 7.1. To address this:
  • Double-check that the device tree overlay is correctly applied.
  • Confirm the RPMsg driver registration as mentioned above.
  • Ensure the memory allocation for RPMsg communication is accurate.
If the problem continues, you may need to delve into the power domain configuration within your custom device tree.
I hope this helps resolve your issue!
Cortex-M RPMsg Guide | Toradex Developer Center.
Dear @marekh,
Thank you for providing this information. That is an interesting situation. May I ask if you have checked whether the M4 itself is running? I am asking this, because if not, then RPMSG will not work either unfortunately, which would explain this behaviour.
One further question that poses itself is how exactly you start the M4. Could you explain this to me so we get a better grasp of the situation?
Collin
Hello Collin,
sorry for late response, there were some other priorities. M4 is running for sure, I see printouts over serial port. M4 thread dealing with RPMSG is waiting for rpmsg_lite_is_link_up (from mcuxpresso SDK) to return true - this happens after Linux sets it up.
M4 is started through u-boot (bootaux). Since parts of the firmware are in DDR, I’m not sure if starting it through the remoteproc is even an option.
Marek
Dear @marekh,
Thank you for letting us know. We have noticed that you are not the only one experiencing these issues, so I have escalated this matter and will get back to you as soon as I have any valid solution.
Collin
@collin.tx Was there ever any resolution to this? I am trying to do board bringup with a similar setup and am also seeing this issue.
Thanks,
Henry
Hello @hroth and @marekh,
The issue around loading firmwares to the Corex-M on u-boot was related to the SCFW.
A way to avoid the problem is to use Remoteproc on Linux to load the firmware.
This is supported since BSP/Torizon OS 7.3.0.
Therefore, I would recommend that you try with BSP/Torizon OS 7.4.0 using remoteproc.
Bruno
The issue with loading the M4 firmware through u-boot still persists in BSP 7.4.0. We haven’t tried the remoteproc way, since we weren’t sure if it supports having parts of FW in DDR.
In the end I managed to find workaround by not registering MU5 power domain (see enclosed patch). Thus when system starts shutting down MUs because of the SCFW issue, it won’t halt RPMSG communication. You’ll still see error about inability to turn off mu_a1 - that’s because SCU cannot turn off MU that is used for communication between Linux and itself. So far it doesn’t seem to break anything.
mu5-power-domain.patch (580 Bytes)
Just to note, since we’re now using the remoteproc dtb node instead of the rpmsg one in the kernel 6.6, as per NXP and Toradex examples, we had to add M4 FW copying resource table (shown in MCUxpresso examples). Older rpmsg node wasn’t using it.
Marek
Hello @marekh,
Thanks for the update and for sharing your workaround.
Bruno
