RPMsg device nodes not appearing in /dev after booting M7 and loading imx_rpmsg_tty on Verdin iMX8MP
Hello Team,
I’m working on enabling communication between Cortex-M7 and Cortex-A53 cores on the Verdin iMX8MP module using RPMsg.
Setup:
  • Booting M7 core via U-Boot using the following commands:(SD_BOOT)
setenv load_cmd “ext4load mmc 1:2”
setenv cm_image “/home/rpmsg_lite_pingpong_rtos_linux_remote.bin”
setenv cm_isize 20000
setenv load_cm_image “${load_cmd} ${loadaddr} ${cm_image}”
setenv cm_boot “${load_cm_image}; cp.b ${loadaddr} 0x7e0000 ${cm_isize}; dcache flush; mw.w 0x550ff000 0 64; bootaux 0x7e0000”
run cm_boot
43792 bytes read in 3 ms (13.9 MiB/s)
No elf image at address 0x007e0000
Starting auxiliary core stack = 0x20020000, pc = 0x000004DD…
  • DT Overlay passed: verdin-imx8mp_hmp_overlay.dtbo
  • Using the rpmsg_lite_pingpong_rtos_linux_remote example from the MCUXpresso SDK
Observations:
  • Kernel logs show that the RPMsg framework is initialized:
    dmesg | grep -i rpmsg
    [ 0.035695] imx rpmsg driver is registered.
I can see the modules are loaded:
lsmod
imx_rpmsg_pingpong 12288 0
imx_rpmsg_tty 16384 0
Problem: No /dev/rpmsg* or /dev/ttyRPMSG* nodes are created:
ls /dev/ | grep -i rpmsg
No output
prem0919
Hello Prem,
Thank you for the detailed explanation of your setup and the steps you’ve followed. Let’s go through a checklist and suggest possible solutions for the missing /dev/ttyRPMSG* device nodes:
1. Memory Address Configuration
Your U-Boot script loads the M7 firmware to 0x7e0000, which is consistent with the TCM (Tightly Coupled Memory) region typically used for the M7 core on Verdin iMX8MP. Please ensure that the resource table memory address (0x550ff000 in your script) matches the address specified in your device tree overlay (Reference: Device Tree Modifications).
2. Device Tree Overlay
  • Make sure that the verdin-imx8mp_hmp_overlay.dtbo sets the correct memory regions for RPMsg, VRING base addresses, and the resource table. Incorrect configuration here will prevent the Linux side from communicating with the M7 RPMsg instance.
  • Double-check that you are including the overlay in your extlinux configuration or via U-Boot variables.
3. Verifying M7 Firmware Execution
  • After booting, connect to the M7 debug UART (UART4 is typically the default).
  • Check for the output:
    RPMSG Ping-Pong FreeRTOS RTOS API Demo...
    Link is up!
    Nameservice announce sent.
    If you don’t see this, the firmware may not be running or initializing RPMsg correctly (Case Oriented Examples).
4. Kernel Module Loading
  • The standard order is to load the base rpmsg driver, e.g.:
    modprobe imx_rpmsg_tty
  • Check with dmesg | grep -i rpmsg for any warnings or error messages after loading the driver.
5. Linux Kernel Parameters (Preventing M-core Interruptions)
  • On recent Torizon OS or upstream kernels, you may need to add specific kernel command line arguments to prevent Linux from taking over the M7 core and interrupting its operation. Community reports have found that without this, devices like /dev/ttyRPMSG* are not created (Related Community Topic).
6. Additional Troubleshooting Steps
  • Confirm your image is NOT an ELF but a binary file. The “No elf image at address 0x007e0000” is not blocking, but ensure you use the correct file format.
  • Make sure you are not missing any mandatory systemd services or udev rules to create the /dev/ttyRPMSG* node.
  • Try rebuilding your MCUXpresso firmware example, and verify you’re using a version compatible with your Linux drivers and device tree overlay.
If all above items are confirmed and the problem persists, please check carefully for any mismatches between the addresses and configuration in the firmware, the device tree, and the Linux kernel.
Useful documentation for further details:
Would you like more specific guidance on checking the device tree or kernel arguments?
Hi @prem0919!
After you run run cm_boot, do you see any outputs in the Cortex M terminal?
Best regards.
Hi @lucas_az.tx ,
when i load rpmsg_lite_pingpong_rtos_linux_remote.bin using bootaux, i can able to see the following message on cortex M console.
RPMSG Ping-Pong FreeRTOS RTOS API Demo…
R5M Share Base Addr is 0x55000000
After loading the firmware then i booted the linux by applying the hmp_overlay after this loaded the imx_rpmsg_tty driver but i cannot find any rpmsg node in /dev
Hi @lucas_az.tx ,
I now able to see the /dev/ttyRPMSG30 node by setting the clk for M7.
And the linux boots i can the following msg on cortex M7 console.
Link is up!
Waiting for ping…
But when i try to send any message using echo prem > /dev/ttyRPMSG30
The following dmesg error i am facing.
[ 63.496104] imx-rproc imx8mp-cm7: imx_rproc_kick: failed (1, err:-62)
[ 63.604133] imx-rproc imx8mp-cm7: imx_rproc_kick: failed (1, err:-62)
And on the M7 console:
Sending pong…
Ping pong done, deinitializing…
Looping forever…
Hi @prem0919!
One way to test this demo is to run modprobe imx_rpmsg_pingpong, which will send and receive 100 messages between the Linux and the Cortex-M. As far as I know, to do it manually by echoing a message through /dev, you should use the rpmsg_lite_str_echo_rtos demo.
That being said, I’ve found this “workaround” on the NXP site. I’ve tested it, and it solves the issue with the imc_rproc_kick:
Best regards
Hi lucas and @ prem0919!
I am also encouuntring same iisue in torizon os 7.6.1 ,did we have any solution to solve this
Hi Prem,
I am also experiencing same issue,did you able to solve this issue,if yes please suggest for me also.
Hi @Somesh!
Were you able to resolve this issue? Which module are you using, and what is its PID?
Best regards.
currently the a53-m4 communication is on hold.i am using imx8m mini duallitesom module
Hi @Somesh!
This thread is focused on the Verdin iMX8M Plus. If you need further assistance with a different topic, please open a new thread.
Best regards.
