RPMSG character driver on Apalis IMX8QM
I have create a communication protocol between core A53 and M40 on apalis IMX8 (using rpmsg character driver and using linux toradex 5.7.2). I created the endpoints successfully like the picture, but when I send message from A53, M4 cannot receive this message.
Here are my code on A53 and M4:
A53:
void IPCStateMachine::run(QQueue<IPCEventData> &eventQueue, QMutex &mutex)
    msg_data_t data_buf = {
        "Hello World!"
    fprintf(stderr, "==========================\n");
    fprintf(stderr, "* RPMsg Hello World demo *\n");
    fprintf(stderr, "Creating endpoint...\n");
    struct rpmsg_endpoint_info ept_info = {"rpmsg-openamp-demo-channel", 0x2, 0x1e};
    int fd = open("/dev/rpmsg_ctrl0", O_RDWR);
    fprintf(stderr, "File descriptor created '%d'\n", fd);
    fprintf(stderr, "Channel info: '%s' [ '%x' --> '%x' ]\n", ept_info.name, ept_info.src, ept_info.dst);
    /* create endpoint interface */
    int ret = ioctl(fd, RPMSG_CREATE_EPT_IOCTL, &ept_info);  // /dev/rpmsg0 is created
    fprintf(stderr, "Endpoint created\n");
    if(ret < 0) qDebug() << "Failed to create ept!!!";
    else qDebug() << "Success to create ept!!!";
    /* create endpoint */
    int fd_ept = open("/dev/rpmsg0", O_RDWR); // backend creates endpoint
    if(fd_ept < 0)
        qDebug() << "End point cannot created!";
    fprintf(stderr, "Endpoint file descriptor created '%d'\n", fd_ept);
    /* send data to remote device */
    fprintf(stderr, "Sending...\n");
    write(fd_ept, &data_buf, sizeof(data_buf));
    /* receive data from remote device */
//     fprintf(stderr, "Receiving...\n");
//     read(fd_ept, &data_buf, sizeof(data_buf));
    /* destroy endpoint */
    fprintf(stderr, "Destroying endpoint...\n");
    ioctl(fd_ept, RPMSG_DESTROY_EPT_IOCTL);
    fprintf(stderr, "Endpoint destroyed\n");
    close(fd_ept);
    close(fd);
M4:
 * Copyright (c) 2016, Freescale Semiconductor, Inc.
 * Copyright 2016-2017 NXP
 * All rights reserved.
 * SPDX-License-Identifier: BSD-3-Clause
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include "rpmsg_lite.h"
#include "rpmsg_queue.h"
#include "rpmsg_ns.h"
#include "pin_mux.h"
#include "clock_config.h"
#include "board.h"
#include "fsl_debug_console.h"
#include "FreeRTOS.h"
#include "task.h"
#include "fsl_lpuart.h"
#include "fsl_irqsteer.h"
#include "rsc_table.h"
 * Definitions
#define RPMSG_LITE_SHMEM_BASE         (VDEV1_VRING_BASE)
#define RPMSG_LITE_LINK_ID            (RL_PLATFORM_IMX8QM_M4_A_USER_LINK_ID)
#define RPMSG_LITE_NS_ANNOUNCE_STRING "rpmsg-openamp-demo-channel"
#define APP_TASK_STACK_SIZE (256)
#ifndef LOCAL_EPT_ADDR
#define LOCAL_EPT_ADDR (30)
#endif
/* Globals */
static char app_buf[512]; /* Each RPMSG buffer can carry less than 512 payload */
 * Prototypes
 * Code
static TaskHandle_t app_task_handle = NULL;
static void ipcIf_nameservice_isr_cb(uint32_t new_ept, const char *new_ept_name, uint32_t flags, void *user_data)
static char helloMsg[13];
static void app_task(void *param)
    volatile uint32_t remote_addr;
    struct rpmsg_lite_endpoint *volatile my_ept;
    volatile rpmsg_queue_handle my_queue;
    struct rpmsg_lite_instance *volatile my_rpmsg;
    void *rx_buf;
    uint32_t len;
    int32_t result;
    void *tx_buf;
    uint32_t size;
    /* Print the initial banner */
    PRINTF("\r\n...RPMSG String Echo FreeRTOS RTOS API Demo...v227\r\n");
#ifdef MCMGR_USED
    uint32_t startupData;
    /* Get the startup data */
    (void)MCMGR_GetStartupData(kMCMGR_Core1, &startupData);
    my_rpmsg = rpmsg_lite_remote_init((void *)startupData, RPMSG_LITE_LINK_ID, RL_NO_FLAGS);
    /* Signal the other core we are ready */
    (void)MCMGR_SignalReady(kMCMGR_Core1);
#else
    my_rpmsg = rpmsg_lite_remote_init((void *)RPMSG_LITE_SHMEM_BASE, RPMSG_LITE_LINK_ID, RL_NO_FLAGS);
#endif /* MCMGR_USED */
    while (0 == rpmsg_lite_is_link_up(my_rpmsg))
    my_queue = rpmsg_queue_create(my_rpmsg);
    my_ept   = rpmsg_lite_create_ept(my_rpmsg, LOCAL_EPT_ADDR, rpmsg_queue_rx_cb, my_queue);
    rpmsg_ns_bind(my_rpmsg, ipcIf_nameservice_isr_cb, NULL);
    (void)rpmsg_ns_announce(my_rpmsg, my_ept, RPMSG_LITE_NS_ANNOUNCE_STRING, RL_NS_CREATE);
    PRINTF("\r\nNameservice sent, ready for incoming messages, wait wait...\r\n");
    for (;;)
        // (void)rpmsg_ns_announce(my_rpmsg, my_ept, "Waiting for new data...", RL_NS_CREATE);
        PRINTF("\nM4 Running.....");
        /* Get RPMsg rx buffer with message */
        /*result =*/ (void)rpmsg_queue_recv(my_rpmsg, my_queue, (uint32_t )&remote_addr, helloMsg, sizeof(helloMsg), ((void *)0),
                           RL_BLOCK + 2000);
            // rpmsg_queue_recv_nocopy(my_rpmsg, my_queue, (uint32_t *)&remote_addr, (char **)&rx_buf, &len, RL_BLOCK + 2000);
            PRINTF("\nRemote addr: %x", remote_addr);
        if (result != 0)
            // assert(false);
            PRINTF("\nresult != 0");
            continue;
        PRINTF("\nM4 Running...1");
        /* Copy string from RPMsg rx buffer */
        // assert(len < sizeof(app_buf));
        memcpy(app_buf, rx_buf, len);
        app_buf[len] = 0; /* End string by '\0' */
        if ((len == 2) && (app_buf[0] == 0xd) && (app_buf[1] == 0xa))
            PRINTF("Get New Line From Master Side\r\n");
        else
            PRINTF("Get Message From Master Side : \"%s\" [len : %d]\r\n", app_buf, len);
        /* Get tx buffer from RPMsg */
        tx_buf = rpmsg_lite_alloc_tx_buffer(my_rpmsg, &size, RL_BLOCK);
        // assert(tx_buf);
        /* Copy string to RPMsg tx buffer */
        memcpy(tx_buf, app_buf, len);
        PRINTF("\nM4 Running...2");
        /* Echo back received message with nocopy send */
        result = rpmsg_lite_send_nocopy(my_rpmsg, my_ept, remote_addr, tx_buf, len);
        if (result != 0)
            // assert(false);
            PRINTF("\nresult != 0 .. 2");
            continue;
        PRINTF("\nM4 Running...3");
        /* Release held RPMsg rx buffer */
        result = rpmsg_queue_nocopy_free(my_rpmsg, rx_buf);
        if (result != 0)
            // assert(false);
            PRINTF("\nresult != 0 .. 3");
            continue;
 * @brief Main function
int main(void)
    /* Initialize standard SDK demo application pins */
    sc_ipc_t ipc;
    ipc = BOARD_InitRpc();
    BOARD_InitPins(ipc);
    BOARD_BootClockRUN();
    BOARD_InitDebugConsole();
    BOARD_InitMemory();
    /* Power up the MU used for RPMSG */
    if (sc_pm_set_resource_power_mode(ipc, SC_R_MU_5B, SC_PM_PW_MODE_ON) != SC_ERR_NONE)
        PRINTF("Error: Failed to power on MU!\r\n");
    if (sc_pm_set_resource_power_mode(ipc, SC_R_MU_7A, SC_PM_PW_MODE_ON) != SC_ERR_NONE)
    if (sc_pm_set_resource_power_mode(ipc, SC_R_IRQSTR_M4_0, SC_PM_PW_MODE_ON) != SC_ERR_NONE)
        PRINTF("Error: Failed to power on IRQSTEER!\r\n");
    IRQSTEER_Init(IRQSTEER);
    copyResourceTable();
#ifdef MCMGR_USED
    /* Initialize MCMGR before calling its API */
    (void)MCMGR_Init();
    if (xTaskCreate(app_task, "APP_TASK", APP_TASK_STACK_SIZE, NULL, tskIDLE_PRIORITY + 1, &app_task_handle) != pdPASS)
        PRINTF("\r\nFailed to create application task\r\n");
        for (;;)
    vTaskStartScheduler();
    PRINTF("Failed to start FreeRTOS on core0.\n");
    for (;;)
Please help me this problem
Hi @victorduong , was the following message printed on M4 debug console? Or was it only the message sent from your Qt application that M4 couldn’t read?
Will sending a message by command work? For example,
echo "this is a test from Linux" > /dev/ttyRPMSG30
This message was printed on M4 debug console. But M4 did not receive any message (“Hello world!”) from A53.
I tried to config rpmsg using character driver on A53 (not rpmsg with tty driver), so I cannot not do this way
In addition, when I config A53 using rpmsg using tty driver, it worked correctly. But when I change to character driver, it did not work.
Hi @victorduong , I can reproduce this problem here. Please allow me to investigate.
Hi @victorduong , I have not brought rpmsg_char up on Apalis iMX8 even with kernel v5.15. Does the rpmsg_tty work for you? This driver is working out-of-the-box.
I have had similar experiences with the RPMSG Character device drivers.
In my case I found that the corresponding devices ‘/dev/rpmsg_ctrl0’ and ‘/dev/rpmsg0’ could only be used by root.
A udev_rule was missing or you have to set the right permissions manually.
You can also use a udev rule to link a small program that creates the respective device (rpmsg0). Otherwise it will be difficult to access it from a Docker container once you create it from there.
Unfortunately, I haven’t progressed that far yet. But maybe it will help you.
Hi @victorduong , We found the reason the char driver uses virtio0 when communicating with rpmsg_string_echo demo on M4 core. In your code, int fd = open("/dev/rpmsg_ctrl0", O_RDWR); will be changed to int fd = open("/dev/rpmsg_ctrl1", O_RDWR); to make char driver work.
Here is another demo we tested.
rpmsg_char_linux_demo.c (2.0 KB)
