It sounds like you’re encountering a challenging issue with the rpmsg_lite_send_nocopy function on your i.MX8MM platform, resulting in a hard fault or an ERROR_VRING_NO_BUFF error. This typically points to a problem with buffer management or memory allocation. Here are some steps to help you troubleshoot and resolve this issue:
Memory Allocation and Device Tree Configuration:
- Verify that the memory regions used by RPMsg are correctly defined in your device tree. Ensure that the reserved memory regions for RPMsg are properly allocated and do not overlap with other memory regions.
- Check the device tree overlays provided by Toradex for RPMsg and ensure they are correctly applied.
Buffer Management:
- The incorrect
head_idxvalue suggests there might be an issue with buffer management. Ensure that buffer indices are correctly tracked and updated. - Confirm that the buffer sizes and counts are correctly configured in your RPMsg setup. The number of buffers and their sizes should match between the A53 and M4 cores.
- The incorrect
Synchronization and Timing:
- Ensure proper synchronization between the A53 and M4 cores. Timing issues can lead to incorrect buffer indices if one core is reading or writing to a buffer that the other core is not ready for.
Code Review and Debugging:
- Review your implementation of the RPMsg functions, especially around
rpmsg_lite_send_nocopyandrpmsg_queue_recv_nocopy. Ensure all parameters and return values are handled correctly. - Use debugging tools to step through the code and monitor variable values, particularly around buffer management functions.
Example Code Comparison:
- Compare your implementation with the
rpmsg_lite_str_echo_rtosexample to ensure all necessary steps and configurations are correctly followed.
By carefully reviewing these aspects, you should be able to identify and resolve the issue causing the hard fault or buffer error. If the problem persists, consider simplifying the setup to isolate the issue further.
I hope this helps you resolve the issue. If you have any more questions, feel free to ask.
Toradex AI Assistant
已解决: Where is the RPMsg document for IMX8MM? - NXP Community.
