hello dear support
I need to rotate my RGB display 180 degrees in BSP6.4 Yocto referenced image
I am using my own display configuration in device tree overlays, as shown below: :
&backlight {
pwms = <&pwm3 0 100000 1>;
brightness-levels = <0 4 8 16 32 64 128 255>;
default-brightness-level = <7>;
&lcd_display {
/* use the bus-format as specified from the panel */
interface-pix-fmt = "";
&panel_dpi {
data-mapping = "bgr666";
I have tried several methods mentioned in the following links, but none of them seem to work for me:
i have tried :
I am using :
Colibri IMX6 + iris + BSP6.4 upstream + custom device tree overlays and zImage
would you please help me to rotate my LCD
I wish you the best
Mehdi
