rootfs sign using meta-integrity for colibri imx7d
Implementing Secure Boot for Colibri iMX7D
For implementing signed applications and secure boot on your Colibri iMX7D module, Toradex provides a dedicated security layer rather than using the generic meta-security/meta-integrity layers.
Recommended Approach: Use Toradex Security Layer
Instead of manually adding meta-security/meta-integrity layers, Toradex provides the meta-toradex-security layer specifically designed for secure boot implementation on Toradex modules.
The Colibri iMX7D supports secure boot with the following features:
  • Bootloader signature checking via NXP’s High Assurance Boot (HAB)
  • FIT image signature checking for kernel and device trees
  • Rootfs signature checking using dm-verity
  • U-Boot hardening with command whitelisting
Configuration Steps
  1. Enable Secure Boot Classes
Add one of these classes to your local.conf (1):
# For full secure boot including rootfs verification
INHERIT += "tdxref-signed"
# Or for secure boot without rootfs dm-verity (if rootfs signing causes issues)
INHERIT += "tdx-signed"
  1. Configure Your Image for dm-verity
If using tdxref-signed, specify your image recipe:
DM_VERITY_IMAGE = "your-image-name"
  1. Machine Configuration
Ensure your machine is correctly set for Colibri iMX7D (1):
MACHINE ?= "colibri-imx7"
# or for eMMC variant
MACHINE ?= "colibri-imx7-emmc"
ACCEPT_FSL_EULA = "1"
Troubleshooting the Service Failures
The systemd service failures you’re experiencing are likely due to:
  1. Read-only rootfs conflicts: When using dm-verity, the rootfs becomes read-only, which can cause issues with services that need to write to system directories.
  2. Missing data partition: Services like systemd-machine-id-commit need writable storage.
Solution: Add Data Partition
For persistent data storage with secure boot, use the tdx-tezi-data-partition class (2):
INHERIT += "tdx-tezi-data-partition"
This creates a separate writable partition for data that persists across updates while keeping the rootfs read-only and verified.
Alternative Approach
If you continue experiencing issues with full rootfs verification, consider using tdx-signed instead of tdxref-signed. This provides bootloader and kernel signing without the dm-verity rootfs verification that may be causing your service failures.
Key Differences from Generic IMA/EVM
Toradex’s secure boot implementation is specifically optimized for embedded systems and provides:
  • Hardware-anchored root of trust
  • Atomic updates with rollback capability
  • Integration with Toradex Easy Installer
  • Support for persistent data partitions
The Colibri iMX7D is confirmed to support secure boot features (3), so the recommended approach is to use Toradex’s proven security layer rather than implementing a custom IMA/EVM solution.
