rootfs sign using meta-integrity for colibri imx7d
We are using colibri imx7d som. we have compiled yocto 7.3 version. we want to implement Signed application to run on my som for that we have included meta-security/meta-integrity layers in bblayers.conf and also generated keys using that layer and included those keys in local.conf, we have compiled image and verified keys are there in /etc/keys/ folder and also Set required config parameters . when i am enabling strict ima-policy then we are getting errors like
[FAILED] Failed to start Commit a transient machine-id on disk.
See “systemctl status systemd-machine-id-commit.service” for details.
[FAILED] Failed to start Network Service.
See “systemctl status systemd-networkd.service” for details.
[FAILED] Failed to start Login Service.
See “systemctl status systemd-logind.service” for details.
so we are unable to sign rootfs. so please suggest where we went wrong.
Implementing Secure Boot for Colibri iMX7D
For implementing signed applications and secure boot on your Colibri iMX7D module, Toradex provides a dedicated security layer rather than using the generic meta-security/meta-integrity layers.
Recommended Approach: Use Toradex Security Layer
Instead of manually adding meta-security/meta-integrity layers, Toradex provides the meta-toradex-security layer specifically designed for secure boot implementation on Toradex modules.
The Colibri iMX7D supports secure boot with the following features:
  • Bootloader signature checking via NXP’s High Assurance Boot (HAB)
  • FIT image signature checking for kernel and device trees
  • Rootfs signature checking using dm-verity
  • U-Boot hardening with command whitelisting
Configuration Steps
  1. Enable Secure Boot Classes
Add one of these classes to your local.conf (1):
# For full secure boot including rootfs verification
INHERIT += "tdxref-signed"
# Or for secure boot without rootfs dm-verity (if rootfs signing causes issues)
INHERIT += "tdx-signed"
  1. Configure Your Image for dm-verity
If using tdxref-signed, specify your image recipe:
DM_VERITY_IMAGE = "your-image-name"
  1. Machine Configuration
Ensure your machine is correctly set for Colibri iMX7D (1):
MACHINE ?= "colibri-imx7"
# or for eMMC variant
MACHINE ?= "colibri-imx7-emmc"
ACCEPT_FSL_EULA = "1"
Troubleshooting the Service Failures
The systemd service failures you’re experiencing are likely due to:
  1. Read-only rootfs conflicts: When using dm-verity, the rootfs becomes read-only, which can cause issues with services that need to write to system directories.
  2. Missing data partition: Services like systemd-machine-id-commit need writable storage.
Solution: Add Data Partition
For persistent data storage with secure boot, use the tdx-tezi-data-partition class (2):
INHERIT += "tdx-tezi-data-partition"
This creates a separate writable partition for data that persists across updates while keeping the rootfs read-only and verified.
Alternative Approach
If you continue experiencing issues with full rootfs verification, consider using tdx-signed instead of tdxref-signed. This provides bootloader and kernel signing without the dm-verity rootfs verification that may be causing your service failures.
Key Differences from Generic IMA/EVM
Toradex’s secure boot implementation is specifically optimized for embedded systems and provides:
  • Hardware-anchored root of trust
  • Atomic updates with rollback capability
  • Integration with Toradex Easy Installer
  • Support for persistent data partitions
The Colibri iMX7D is confirmed to support secure boot features (3), so the recommended approach is to use Toradex’s proven security layer rather than implementing a custom IMA/EVM solution.
