I think the sensitivity is much better, but still seeing problem i said with pressing repeatedly the same point. I’m attaching a piece of the log
Event: time 1527086913.354719, type 3 (EV_ABS), code 0 (ABS_X), value 290
Event: time 1527086913.354719, type 3 (EV_ABS), code 1 (ABS_Y), value 2734
Event: time 1527086913.354719, type 3 (EV_ABS), code 24 (ABS_PRESSURE), value 2
Event: time 1527086913.354719, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 1
Event: time 1527086913.354719, -------------- SYN_REPORT ------------
Event: time 1527086913.394093, type 3 (EV_ABS), code 0 (ABS_X), value 293
Event: time 1527086913.394093, type 3 (EV_ABS), code 1 (ABS_Y), value 2735
Event: time 1527086913.394093, type 3 (EV_ABS), code 24 (ABS_PRESSURE), value 1
Event: time 1527086913.394093, -------------- SYN_REPORT ------------
Event: time 1527086913.434244, type 3 (EV_ABS), code 24 (ABS_PRESSURE), value 0
Event: time 1527086913.434244, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 0
Event: time 1527086913.434244, -------------- SYN_REPORT ------------
Event: time 1527086913.729707, type 3 (EV_ABS), code 0 (ABS_X), value 296
Event: time 1527086913.729707, type 3 (EV_ABS), code 1 (ABS_Y), value 2731
Event: time 1527086913.729707, type 3 (EV_ABS), code 24 (ABS_PRESSURE), value 1
Event: time 1527086913.729707, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 1
Event: time 1527086913.729707, -------------- SYN_REPORT ------------
Event: time 1527086913.769054, type 3 (EV_ABS), code 0 (ABS_X), value 298
Event: time 1527086913.769054, type 3 (EV_ABS), code 1 (ABS_Y), value 2735
Event: time 1527086913.769054, -------------- SYN_REPORT ------------
Event: time 1527086913.808942, type 3 (EV_ABS), code 24 (ABS_PRESSURE), value 0
Event: time 1527086913.808942, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 0
Event: time 1527086913.808942, -------------- SYN_REPORT ------------
Event: time 1527086914.069851, type 3 (EV_ABS), code 0 (ABS_X), value 290
Event: time 1527086914.069851, type 3 (EV_ABS), code 1 (ABS_Y), value 2737
Event: time 1527086914.069851, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 1
Event: time 1527086914.069851, -------------- SYN_REPORT ------------
Event: time 1527086914.110000, type 3 (EV_ABS), code 0 (ABS_X), value 857
Event: time 1527086914.110000, type 3 (EV_ABS), code 1 (ABS_Y), value 2855
Event: time 1527086914.110000, type 3 (EV_ABS), code 24 (ABS_PRESSURE), value 8
Event: time 1527086914.110000, -------------- SYN_REPORT ------------
Event: time 1527086914.150062, type 3 (EV_ABS), code 24 (ABS_PRESSURE), value 0
Event: time 1527086914.150062, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 0
Event: time 1527086914.150062, -------------- SYN_REPORT ------------
As you can see we are pressing aprox point 290,2730 but the last one you can see 857, 2850 even if i was touching the same point
As we said we will also try to use another cable to check if it’s part of the problem
