Resistive Touch Input - Device Tree Overlay
Hardware:
Colibri iMX6DL
with Viola Carrier Board Rev 1.2
TorizonCore 5.7.2
Hi there,
We have a LCD display + Resistive Touch connected via the Unified Interface Display Connector (X7). The LCD display is working with the required device tree overlay support.
The TOUCH_TSPY + TOUCH_TSMX + TOUCH_TSMY + TOUCH_TSPX signals are connected (via the X7 ribbon cable). Is there a device tree overlay file to support this?
Would the ‘colibri-imx6_stmpe-ts_overlay.dts’ file be the correct way to enable the touch input for this form of interface.
i.e. include this DTO
 * Copyright 2020-2021 Toradex
// Resitive STMPE touchscreen touchscreen for the 7inch display orderable at Toradex.
/dts-v1/;
/plugin/;
	compatible = "toradex,colibri_imx6dl";
&stmpe_ts {
Many Thanks Jon
Hello @jon2023 ,
Could you please share with us the data sheet of the screen that you are using?
Josep
Yeah sure,
MDT0280A1IHR-MULTI.pdf (1.7 MB)
There’s not much on the Resistive Touch interface, just a list of the signals on page 5.
Hello @jon2023 ,
your screen has a 4-wire touch interface, so the overlay that you mention should work.
Please let us know the results.
Josep
Thanks Josep, I’ll try that
Hi Joesp,
Brilliant. That worked first time…
