Required property in dtsi file for both ethernet working
Hi team,
kernel version : Linux colibri-imx6ull 4.9.84-+gb2a7f2f #2 SMP Thu Jan 21 17:56:57 IST 2018 armv7l GNU/Linux
We see below the lines in driver file. do we need to add “fsl,mii-exclusive” property in dtsi file for both ethernet working? if yes then in which node we need to add? fec1 or fec2?
drivers/net/ethernet/freescale/fec_main.c
	/* board only enable one mii bus in default */
	if (!of_get_property(np, "fsl,mii-exclusive", NULL))
		fep->quirks |= FEC_QUIRK_SINGLE_MDIO;
	ret = fec_enet_mii_init(pdev);
	if (ret)
		goto failed_mii_init;
Hi @all
any update for the issue ??
Regrads,
Nikunj
Hi @nikunjp26
We are not using this property in any of device-tree files? So I don’t think, it is needed.
