Request for Provision to Flash Containerized Application via SSH Without Recovery Mode
Dear Toradex Support Team,
We are currently working with Toradex SoMs and using containerized applications for deployment. As per the current procedure for flashing or updating the system requires entering recovery mode, which involves manually pressing the recovery button and using a USB drive or SD card.
However, this approach becomes challenging in field deployments where physical access to open the unit is limited or not feasible. Therefore, we would like to know if Toradex provides (or can provide) a provision to flash or update the containerized application via SSH or any other mode, without the need to open the unit.
If there is any existing method or recommended approach for achieving this, we would greatly appreciate your guidance.
Thank you for your support, and we look forward to your response.
Software summary
Bootloader: U-Boot
Kernel version: 6.1.71-6.5.0+git.38fb82ecd144 #1-TorizonCore SMP Tue Dec 19 14:52:07 UTC 2023
Kernel command line: root=LABEL=otaroot rootfstype=ext4 quiet logo.nologo vt.global_cursor_default=0 plymouth.ignore-serial-consoles splash fbcon=map:3 ostree=/ostree/boot.1/torizon/b9a2dcf7fbf43a6103fa51110ba4e2541289013d869f8e87182cf862a2f2bedb/0 console=null
Distro name: NAME=“TorizonCore Upstream”
Distro version: VERSION_ID=6.5.0-build.8
Distro variant: VARIANT=“Docker”
Hostname: colibri-imx7-emmc-14952875
Hardware info
HW model: Toradex Colibri iMX7D 1GB (eMMC) on Colibri Evaluation Board V3
Toradex version: 0039 V1.1B
Serial number: 14952875
Processor arch: armv7l
Thank you,
Saikrishna
Sr. R&D Engineer
BPL Medical Technologies Pvt Ltd
Hi @Saikrishna
Well… we have our OTA remote updates solution,
which is better than SSH-ing into devices in the field for a few reasons.
You can read a detailed review about this solution in these pages.
