Hi Team,
We are changing the SBC Colibri T20 with iMX6 series SBC.
The L2 cache memory is reduced to half. will they impact on the performance.
Thanks & Regards
Murugesan A
Hi Team,
Thanks & Regards
Murugesan A
Hi @murugesh,
Thanks for contacting Toradex Community.
Can you please also share details on software running, like what OS, programming language you are using?
Ideally yes less L2 will have some impact on performance but same needs to be verified against your application.
I would suggest to test your application for any performance lag.
Ritesh Kumar
Hi Ritesh,
Good morning,
Thanks for the reply,
We are going to use linux platform.
Thanks & Regards
Murugesan A
