mkock
December 8, 2022, 8:26pm
1
on BSP 5.6. iptables is enabled.
After reboot iptables -L shows:
(no rules for INPUT)
(no rules for ACCEPT )
but rules for OUTPUT
DROP tcp – anywhere anywhere tcp dpt:http
DROP tcp – anywhere anywhere tcp dpt:https
content of /etc/iptables/iptables.rules:
*filter
:INPUT ACCEPT [0:0]
:FORWARD ACCEPT [0:0]
:OUTPUT ACCEPT [0:0]
COMMIT
Deleting the output rules manually works, but after a reboot they are there again which I do not want.
Disabling the pre-installed service (systemctl disable iptables.service) did not change anything.
Is there anything more pre-installed which I do not see?
How can I remove these rules?
Best,
M
Hi @mkock !
I just installed the Reference Minimal Image from BSP 5.7.0 using Toradex Easy Installer on an Apalis iMX6D 512MB V1.1B.
root@apalis-imx6-10692081:~# cat /etc/os-release
ID=tdx-xwayland
NAME="TDX Wayland with XWayland"
VERSION="5.7.0+build.20 (dunfell)"
VERSION_ID=5.7.0-build.20
PRETTY_NAME="TDX Wayland with XWayland 5.7.0+build.20 (dunfell)"
DISTRO_CODENAME="dunfell"
root@apalis-imx6-10692081:~# cat /etc/iptables/iptables.rules
root@apalis-imx6-10692081:~# iptables -L
Chain INPUT (policy ACCEPT)
target prot opt source destination
Chain FORWARD (policy ACCEPT)
Chain OUTPUT (policy ACCEPT)
As you can see above, the iptables.rules file is empty.
By searching for iptables.rules file within the default layers from Toradex’s manifest, this is what I get:
[ 5:41 ] [ ~/yocto/oe-workdir/tdxref-bsp-5/layers ] [ 130 ]
$ cat -pp openembedded-core/meta/recipes-extended/iptables/iptables/iptables.service
[Unit]
Description=IPv4 Packet Filtering Framework
Before=network-pre.target
Wants=network-pre.target
[Service]
Type=oneshot
ExecStart=@SBINDIR@/iptables-restore -w -- @RULESDIR@/iptables.rules
ExecReload=@SBINDIR@/iptables-restore -w -- @RULESDIR@/iptables.rules
RemainAfterExit=yes
[Install]
WantedBy=multi-user.target
$ rg iptables.rules
openembedded-core/scripts/runqemu-ifdown
54:# cleanup the remaining iptables rules
openembedded-core/meta/recipes-extended/iptables/iptables_1.8.4.bb
15: file://iptables.rules \
50: install -m 0644 ${WORKDIR}/iptables.rules ${D}${IPTABLES_RULES_DIR}
8:ExecStart=@SBINDIR@/iptables-restore -w -- @RULESDIR@/iptables.rules
9:ExecReload=@SBINDIR@/iptables-restore -w -- @RULESDIR@/iptables.rules
$ cat -pp openembedded-core/meta/recipes-extended/iptables/iptables/iptables.rules
[ 5:42 ] [ ~/yocto/oe-workdir/tdxref-bsp-5/layers ]
[Unit]
[Service]
Type=oneshot
RemainAfterExit=yes
[Install]
The recipe openembedded-core/meta/recipes-extended/iptables/iptables_1.8.4.bb is only the iptables recipe responsible for the iptables.rules file (which is empty) that I see in my freshly installed image, as we can check using oe-pkgdata-util tool:
pokyuser@9443597fae04:/workdir/tdxref-bsp-5/build$ oe-pkgdata-util find-path /etc/iptables/iptables.rules
iptables: /etc/iptables/iptables.rules
Did you perform any modifications to your image or on your layers?
mkock
December 18, 2022, 7:54pm
3
thanks for your fast reply. I will check again if there is anything in our layers that could affect the iptables behaviour.
Hi @mkock ,
Happy New Year
Is there any updates on this issue ?
Kevin
