Remoteproc dev-tree on IMX8MP
I have a Verdin IMX8M Plus IT V1.0D module and I tried to use the device-tree overlay for remoteproc and followed this documentation:
I tried the .dtbo for imx8mp on branch “toradex_5.15-2.1.x-imx”. The device tree overlay loads successfully but unfortunately it does not work and I cannot see the remoteproc entries in the sysfs.
I found the following entry in the list for branch master and wonder if the dev-tree overlay does not fit to my Linux.
verdin-imx8mp_hmp_overlay.dts     Coming soon     master
I use a BSP with “toradex_5.4-2.3.x-imx” branch, but there the file is not provided. Is there a reason for this?
Is there already a dev-tree overlay for our branch available or how can I make remoteproc work?
Thx in advance and BR
Ralph
Hello @Ralph,
Thank you for reaching out. There is no HMP overlay for BSP5. Therefore we suggest using BSP6.
We have noticed a mistake on our webpage concerning the versioning of the branch. Instead of “toradex_5.15-2.1.x-imx” it should in fact be “toradex_5.15-2.2.x-imx”. I would like to apologize for the mistake an the inconvenience. Efforts will be made to correct this mistake on our webpage.
Concerning the above mentioned listing, this is upstream, which
we would not recommend using. Instead we would suggest using
the overlay verdin-imx8mp_hmp_overlay.dts from
toradex_5.15-2.2.x-imx.
We will test the mentioned constellation on our side in the near future.
Best regards
Collin
Hello Collin,
I read about HPM overlay which is not available for BSP5 (i.e. kernel 5.4.x).
However, I saw remoteproc driver is built with this kernel version so I was wondering how can I setup it for allowing communication between Cortex-A53 and Cortex-M7 in Verdin iMx8MP.
Thanks in advance
Hello @andreabernasconi,
At this point BSP 5 has reached EOL, therefore it is not recommended for new developments.
If you are in a development stage, we recommend using BSP 7, which contains the device tree overlay supporting HMP on the Verdin iMX8MP.
Also, remoteproc is not intended for communication between Cortex-A53 and Cortex-M7, but for managing the Cortex-M7 from Linux on the Cortex-A53. For communication, you can use RPMSG or shared memory.
If you have more questions, please open a new topic here on the community so we can support you directly there.
Bruno
Hello Bruno,
thanks for your feedback.
Updating to new BSP is something I have to do in near future but still I am using BSP 5 I was interesting in remoteproc for start/stop features of cortex-m7.
I tried yesterday and it seems working also with BSP 5.
Thanks again!
Andrea
