For a production scenario it would be nice to have some possibility to log the flash procedure of the EasyInstaller on a remote machine (e.g. by sending packets via netconsole to a host machine). Have you something like that in mind already?
One solution could be to write a prepare_script and a wrapup_script that sends some logging information via nc. You could also check the image health in the wrapup_script after flashing.
Check this link under “Detailed Manual” for more information regarding wrapup_script and prepare_script.
Would such a solution work for your use case?
Stefan
Hi Stefan,
Yes, such a solution would work.
I had some time to care about this.
My setup:
- dhcp server (
192.168.10.1
) - http server (
192.168.10.1
) serving our tezi conform image whithnetcat
piping of log messages inprepare.sh
andwrapup.sh
scripts (see below) - dnsmasq DNS redirect (
192.168.10.1
→tezi.toradex.com
) - Apalis TK1 2GB v.1.2A with EasyInstaller v1.5 pre-flashed
- serial cable attached
The serial console output from EasyInstaller states with ip addr show eth0
that it got 192.168.10.63
which is OK.
Connecting with vnc (krdc
) to EasyInstaller on 192.168.10.63
is OK.
So far so good.
But the EasyInstaller GUI output is NOK:
Error executing prepare script
/var/volatile/Roboception_rc_visard_v1.2.0
/var/volatile/Roboception_rc_visard_v1.2.0/prepare.sh: line 66: netcat: not found
(some other "not found" messages)
The image has not been written completely. Please restart the process, otherwise you might end up in a non-bootable system.
The according content of the prepare.sh
file is:
REMOTE_LOGGING_HOST=192.168.10.1
REMOTE_LOGGING_PORT=12345
echo "Start flashing of rc_visard." | netcat $REMOTE_LOGGING_HOST $REMOTE_LOGGING_PORT
BusyBox netcat is available, its name is nc
Hi Stefan, thx for the hint. Remote logging works just fine.
Hi Florian, you are welcome. Thanks for the feedback.
