I came across this remote-display-linux for something similar which I am trying to achieve. I want to have a remote control over the module.
I am working with Colibri iMX6 running Linux.
Can someone help me with this?
Thank you in advance.
The same article also have the instructions on building the freeRDP client which is also applicable for Colibri iMX6.
Your requirement is not exactly clear however x11vnc might also suit your purpose. One may install it on the module with
opkg install x11vnc
or include it in a custom image build with OpenEmbedded by having
IMAGE_INSTALL_append = "x11vnc"
in ~/oe-core/build/conf/local.conf and then build the image. For information on OpenEmbedded build, please refer the article here.
On any of our modules after installation, x11vnc can be used by invoking the following from command line
x11vnc -display :0
and then from a Linux desktop, one can connect with
vncviewer <ip_address_of_module>:0
Bhuvan!! Thank you for your input. The solution you mentioned works perfect for my requirement.
One more question related to this thread.
I am also trying to achieve file transfer from remote Windows to Colibri iMX6. I have the following command when instantiating a x11vnc server on Colibri iMX6
x11vnc -tightfilexfer which should enable file transfer.
After which I connect using Real VNC running on Windows. I am able to have a remote connection but not able to transfer files from Windows client to Colibri module. The disabled file transfer button reads “VNC server does not support file transfer” on hovering over.
Do you have any idea about this?
PS: I am a newbie to embedded programming.
We never tested file transfer with x11vnc. Atleast from the man page of x11vnc seems it supports UltraVNC and TightVNC file transfer extensions. Have at look at the man page.
We are using Linux colibri-imx6ull 4.9.87-2.8.4, and have tried to setup open vnc.
we have followed below steps:
12/02/2019 13:31:06 x11vnc version: 0.9.13 lastmod: 2011-08-10 pid: 647
12/02/2019 13:31:06 XOpenDisplay(“:0”) failed.
12/02/2019 13:31:06 Trying again with XAUTHLOCALHOSTNAME=localhost …
12/02/2019 13:31:06 ***************************************
12/02/2019 13:31:06 *** XOpenDisplay failed (:0)
*** x11vnc was unable to open the X DISPLAY: “:0”, it cannot continue.
Can you please help up with this ??
Could you please specify which version of Linux BSP you are using? Is it a console only image? If so VNC will not work. Use ssh instead.
thanks @alex.tx for your response,
we are using “colibri-imx6ull_console-image-tezi_2.8b5.156-20181228” console image.
can you suggest the procedure for ssh ? module will be in different network.
You just need to know the ip address of the module and then you can follow these Instructions.
Best regards, Jaski
Hi ,
we are able take ssh when host and colibri module are in same network.
But we want to take ssh or remote access when host and colibri module are in different network.
can you help us how we can do it with “colibri-imx6ull_console-image-tezi_2.8b5.156-20181228” image?
What you mean with different network?
Can you access this module in different network from your network?
Is pinging possible?
How is your network configuration?
What you mean with different network? - The module will be at remote location, it wont be in same network where host is present.
Can you access this module in different network from your network? - no, that’s what we are looking for something like open vnc, but as we are using console image its not possible with it.
Is pinging possible? - No
Could you please specify your network configuration? To remotely access a module you must have ability to send/receive TCP/IP packets between module and a host computer.
We are using OpenSSH_7.5p1, OpenSSL 1.0.2. This software is not Toradex specific, so you can use any available documentation about OpenSSH.
okay, thank you for your input.
Please note that hijacking old questions is discouraged!
i am using imx6ull Aster Carrier Board with TDX Wayland with XWayland Upstream 6.7.0-devel-20240710125113+build.0 (kirkstone) Colibri-iMX6ULL-eMMC_Reference-Multimedia-Image-upstream tdx-reference-multimedia-image (OS)
I followed these steps but i am getting this
x11vnc -display :0
#@ ** WARNING ** WARNING ** WARNING ** WARNING ** @#
#@ YOU ARE RUNNING X11VNC WITHOUT A PASSWORD!! @#
#@ This means anyone with network access to this computer @#
#@ may be able to view and control your desktop. @#
#@ >>> If you did not mean to do this Press CTRL-C now!! <<< @#
#@ You can create an x11vnc password file by running: @#
#@ x11vnc -storepasswd password /path/to/passfile @#
#@ or x11vnc -storepasswd /path/to/passfile @#
#@ or x11vnc -storepasswd @#
#@ (the last one will use ~/.vnc/passwd) @#
#@ and then starting x11vnc via: @#
#@ x11vnc -rfbauth /path/to/passfile @#
#@ an existing ~/.vnc/passwd file from another VNC @#
#@ application will work fine too. @#
#@ You can also use the -passwdfile or -passwd options. @#
#@ (note -passwd is unsafe if local users are not trusted) @#
#@ Make sure any -rfbauth and -passwdfile password files @#
#@ cannot be read by untrusted users. @#
#@ Use x11vnc -usepw to automatically use your @#
#@ ~/.vnc/passwd or ~/.vnc/passwdfile password files. @#
#@ (and prompt you to create ~/.vnc/passwd if neither @#
#@ file exists.) Under -usepw, x11vnc will exit if it @#
#@ cannot find a password to use. @#
#@ Even with a password, the subsequent VNC traffic is @#
#@ sent in the clear. Consider tunnelling via ssh(1): @#
#@ http://www.karlrunge.com/x11vnc/#tunnelling @#
#@ Or using the x11vnc SSL options: -ssl and -stunnel @#
#@ Please Read the documentation for more info about @#
#@ passwords, security, and encryption. @#
#@ http://www.karlrunge.com/x11vnc/faq.html#faq-passwd @#
#@ To disable this warning use the -nopw option, or put @#
#@ 'nopw' on a line in your ~/.x11vncrc file. @#
18/07/2024 11:26:47 x11vnc version: 0.9.16 lastmod: 2019-01-05 pid: 657
18/07/2024 11:26:47 XOpenDisplay(":0") failed.
18/07/2024 11:26:47 Trying again with XAUTHLOCALHOSTNAME=localhost ...
18/07/2024 11:26:47 Wayland display server detected.
18/07/2024 11:26:47 Wayland sessions are as of now only supported via -rawfb and the bundled deskshot utility. Exiting.
Hello Prial,
This is an older ticket, would you mind creating a new ticket and posting your question. This helps us and the community by having the searchable tickets be easier to read, follow, and find solutions already met.
-Eric
