When will the new libraries for T20/T30,supporting 1:1 backup be released ?
we need to schedule when we can implement the backup functionality into our main application.
Thomas
Thomas
The library package should be released soon, but I can’t name you an exact date. In the meantime, you can use the Update Lib Version 2.0.7 from here.
The library has been changed quite a bit. You should be able to use it the same way as before or you can also use it the same way the Update Tool is using it (updating with .cfg files).
