When trying to persist the registry to flash, the API call to RegFlushKey(HKEY_LOCAL_MACHINE) fails.
Calling the same API a second time, it succeeds.
After a reboot, the changed keys/values are no longer present.
While booting the OS display the following messages on the debug serial port:
[8.22 14:37:22.0]Toradex Windows CE 8.0 1.6b1
[8.22 14:37:22.0] for iMX6 Built on Aug 8 2019
[8.22 14:37:22.0]Colibri iMX6 DualLite 512MB
[8.22 14:37:22.2]Multi-core mode is disabled in module configuration.
[8.22 14:37:22.2]Wait mode Disabled
[8.22 14:37:22.2]SMP support disabled
[8.22 14:37:22.2]RTC origin set to: 2006/01/01.
[8.22 14:37:22.2]Registry is empty or invalid. Loading default values.
[8.22 14:37:22.2]Registry loaded.
[8.22 14:37:22.3]Loading GPIO Multiplexer...
When calling RegFlushKey for the first time after chaning a registry value, we get the following on the debug output:
[8.22 14:45:26.7]Registry - Saving is disabled.
This looks like a problem in the BSP.
