I am facing issue while unpacking image file
torizoncore-builder images unpack /home/jitu-rnd/Optimus1/Toradex/Torizon_iMX7/torizon-core-docker-evaluation-colibri-imx7-emmc-Tezi_5.1.0+build.1.container.tar
Storage not empty. Delete current image before continuing? [y/N] y
Unpacking Toradex Easy Installer image.
An unexpected Exception occured. Please provide the following stack trace to
the Toradex TorizonCore support team:
File “/builder/torizoncore-builder”, line 175, in
mainargs.func(mainargs)
File “/builder/tcbuilder/cli/images.py”, line 71, in do_images_unpack
images_unpack(args.image_directory,
File “/builder/tcbuilder/cli/images.py”, line 65, in images_unpack
images.import_local_image(image_dir, dir_list[0], dir_list[1], dir_list[2])
File “/builder/tcbuilder/backend/images.py”, line 161, in import_local_image
subprocess.check_output(tarcmd, shell=True, stderr=subprocess.STDOUT)
File “/usr/lib/python3.9/subprocess.py”, line 424, in check_output
return run(*popenargs, stdout=PIPE, timeout=timeout, check=True,
File “/usr/lib/python3.9/subprocess.py”, line 528, in run
raise CalledProcessError(retcode, process.args,
subprocess.CalledProcessError: Command ‘cat /home/jitu-rnd/Optimus1/Toradex/Torizon_iMX7/torizon-core-docker-evaluation-colibri-imx7-emmc-Tezi_5.1.0+build.1.container.tar | cat | tar -xf - -C /storage/tezi.tmp’ returned non-zero exit status 2.
please check.
Pradeep Pol
