Hi Team,
I’m working on verdin AM62 integrated on verdin development board. I’m connecting a 3.5” MSP3520 TFT display which supports touch facility via SPI3. ADS7846 is the touch controller. Luckily, the ads7846 driver is available in the torizon linux kernel. I used this in my overlay to enable my touchscreen.
Overlay for my tft display:-
🐧 root @GalaxyBook/home/Meenakshy/Projects/SPI_TFT_Display/tcbdir: cat device-trees/overlays/verdin-am62_msp3520_tft_display_spi3_overlay.dts
/dts-v1/;
/plugin/;
#include <dt-bindings/interrupt-controller/irq.h>
#include "k3-pinctrl.h"
compatible = "toradex,verdin-am62";
/* Disable HDMI connector */
&{/hdmi-connector} {
status = "disabled";
/* Disable the HDMI bridge on I2C1 */
&{/bus@f0000/i2c@20010000/hdmi@48} {
/* Disable connector that uses conflicting pins */
&{/connector} {
/* Disable PWM modules */
&epwm0 {
&epwm1 {
/* Pin configuration for SPI0 (Verdin SPI_3) */
&main_pmx0 {
spi3_pins_default: spi3-default-pins {
pinctrl-single,pins = <
AM62X_IOPAD(0x01bc, PIN_OUTPUT, 0) /* (A14) SPI0_CLK - SODIMM 19 */
AM62X_IOPAD(0x01b4, PIN_OUTPUT, 0) /* (A13) SPI0_CS0 - SODIMM 15 */
AM62X_IOPAD(0x01b8, PIN_OUTPUT, 0) /* (C13) SPI0_CS1 - SODIMM 16 */
AM62X_IOPAD(0x01c4, PIN_OUTPUT, 0) /* (B14) SPI0_D1 - MOSI - SODIMM 161 */
AM62X_IOPAD(0x01c0, PIN_INPUT, 0) /* (B13) SPI0_D0 - MISO - SODIMM 66 */
/* MCU GPIO pins configuration */
&mcu_pmx0 {
/* SODIMM 206 - DC pin - gpio-532 (line 1) */
pinctrl_sodimm_206_gpio: sodimm-206-gpio-pins {
AM62X_MCU_IOPAD(0x0004, PIN_OUTPUT, 7) /* MCU_GPIO0_1 - SODIMM 206 */
/* SODIMM 208 - Reset pin - gpio-533 (line 2) */
pinctrl_sodimm_208_gpio: sodimm-208-gpio-pins {
AM62X_MCU_IOPAD(0x0008, PIN_OUTPUT, 7) /* MCU_GPIO0_2 - SODIMM 208 */
/* SODIMM 210 - Backlight pin - gpio-534 (line 3) */
pinctrl_sodimm_210_gpio: sodimm-210-gpio-pins {
AM62X_MCU_IOPAD(0x000c, PIN_OUTPUT, 7) /* MCU_GPIO0_3 - SODIMM 210 */
/* SODIMM 212 - Touch interrupt - gpio-535 (line 4) */
pinctrl_sodimm_212_gpio: sodimm-212-gpio-pins {
AM62X_MCU_IOPAD(0x0010, PIN_INPUT, 7) /* MCU_GPIO0_4 - SODIMM 212 */
/* Enable MCU GPIO controller with all pin groups */
&mcu_gpio0 {
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_sodimm_206_gpio>,
<&pinctrl_sodimm_208_gpio>,
<&pinctrl_sodimm_210_gpio>,
<&pinctrl_sodimm_212_gpio>;
/* Configure SPI0 for display and touchscreen */
&main_spi0 {
pinctrl-0 = <&spi3_pins_default>;
ti,spi-num-cs = <2>;
#address-cells = <1>;
#size-cells = <0>;
/* MSP3520 Display on CS0 */
msp3520_display@0 {
compatible = "rohm,dh2228fv";
reg = <0>;
spi-max-frequency = <32000000>;
reset-gpios = <&mcu_gpio0 2 GPIO_ACTIVE_LOW>; /* SODIMM 208 - Line 2 */
dc-gpios = <&mcu_gpio0 1 GPIO_ACTIVE_HIGH>; /* SODIMM 206 - Line 1 */
led-gpios = <&mcu_gpio0 3 GPIO_ACTIVE_HIGH>; /* SODIMM 210 - Line 3 */
/* ADS7846 Touchscreen on CS1 */
msp3520_touch@1 {
compatible = "ti,ads7846";
reg = <1>;
spi-max-frequency = <2000000>;
vcc-supply = <®_3v3>;
/* CRITICAL: ADD SPI MODE CONFIGURATION */
/*spi-cpol;*/ /* Clock polarity low */
/*spi-cpha; */ /* Clock phase - sample on first edge */
/* This combination gives SPI Mode 0 */
interrupt-parent = <&mcu_gpio0>;
interrupts = <4 IRQ_TYPE_EDGE_FALLING>; /* SODIMM 212 - Line 4 */
pendown-gpio = <&mcu_gpio0 4 GPIO_ACTIVE_LOW>; /* SODIMM 212 - Line 4 */
ti,x-plate-ohms = /bits/ 16 <400>;
ti,y-plate-ohms = /bits/ 16 <400>;
ti,pressure-max = /bits/ 16 <150>;
ti,x-min = /bits/ 16 <0>;
ti,x-max = /bits/ 16 <4095>;
ti,y-min = /bits/ 16 <0>;
ti,y-max = /bits/ 16 <4095>;
ti,settle-delay-usec = /bits/ 16 <150>;
ti,penirq-recheck-delay-usecs = /bits/ 16 <100>;
ti,vref-delay-usecs = /bits/ 16 <100>;
ti,vref-mv = /bits/ 16 <3300>;
ti,debounce-rep = /bits/ 16 <3>;
ti,debounce-tol = /bits/ 16 <25>;
ti,debounce-max = /bits/ 16 <3>;
ti,keep-vref-on;
wakeup-source;
Now I could see interrupt count is increasing, when I touch the screen
torizon@verdin-am62-15415886:~$ cat /proc/interrupts | grep ads7846
312: 0 1 GPIO 4 Edge -davinci_gpio ads7846
312: 872 1 GPIO 4 Edge -davinci_gpio ads7846
Also, evtest is also working. But evtest is giving output for some touch. It’s output is not consistent
torizon@verdin-am62-15415886:~$ evtest /dev/input/event2
Input driver version is 1.0.1
Input device ID: bus 0x1c vendor 0x0 product 0x1ea6 version 0x0
Input device name: "ADS7846 Touchscreen"
Supported events:
Event type 0 (EV_SYN)
Event type 1 (EV_KEY)
Event code 330 (BTN_TOUCH)
Event type 3 (EV_ABS)
Event code 0 (ABS_X)
Value 8
Min 0
Max 4095
Event code 1 (ABS_Y)
Value 1
Min 0
Max 4095
Event code 24 (ABS_PRESSURE)
Value 0
Min 0
Max 150
Properties:
Testing ... (interrupt to exit)
Event: time 1764068211.307261, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 1
Event: time 1764068211.307261, type 3 (EV_ABS), code 0 (ABS_X), value 4
Event: time 1764068211.307261, type 3 (EV_ABS), code 1 (ABS_Y), value 6
Event: time 1764068211.307261, type 3 (EV_ABS), code 24 (ABS_PRESSURE), value 146
Event: time 1764068211.307261, -------------- SYN_REPORT ------------
Event: time 1764068212.945771, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 0
Event: time 1764068212.945771, type 3 (EV_ABS), code 24 (ABS_PRESSURE), value 0
Event: time 1764068212.945771, -------------- SYN_REPORT ------------
Event: time 1764068216.638363, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 1
Event: time 1764068216.638363, type 3 (EV_ABS), code 1 (ABS_Y), value 1
Event: time 1764068216.638363, type 3 (EV_ABS), code 24 (ABS_PRESSURE), value 147
Event: time 1764068216.638363, -------------- SYN_REPORT ------------
Event: time 1764068217.235656, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 0
Event: time 1764068217.235656, type 3 (EV_ABS), code 24 (ABS_PRESSURE), value 0
Event: time 1764068217.235656, -------------- SYN_REPORT ------------
Event: time 1764068248.968563, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 1
Event: time 1764068248.968563, type 3 (EV_ABS), code 0 (ABS_X), value 1
Event: time 1764068248.968563, type 3 (EV_ABS), code 1 (ABS_Y), value 2
Event: time 1764068248.968563, type 3 (EV_ABS), code 24 (ABS_PRESSURE), value 149
Event: time 1764068248.968563, -------------- SYN_REPORT ------------
Event: time 1764068249.605655, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 0
Event: time 1764068249.605655, type 3 (EV_ABS), code 24 (ABS_PRESSURE), value 0
Event: time 1764068249.605655, -------------- SYN_REPORT ------------
Also, pendown value is 1 for some touch, otherwise 0.
cat /sys/bus/spi/devices/spi0.1/pen_down
How to resolve this issue? Why this is giving output for some touch?
Thanks & Regards,
Meenakshy
