Hello!
I’m currently trying to reduce the Display EMC. According to the following guides
I need to modify the device-tree.
So I modified the lines 651-672
in the following file: imx6qdl-colibri.dtsi « dts « boot « arm « arch - linux-toradex.git - Linux kernel for Apalis, Colibri and Verdin modules
I set all values to 0x8
(Speed: Low, DSE: 150 Ohm, SRE: Slow), which should be the lowest possible value.
After that, i created a patch, and applied it to our build system, build the image and flashed it.
I still have a working display so I would like to verify the new pinmux, How do I do that?
I was able to find the node in /proc
and also got a dump with hexdump
, but I don’t know how to compare it with my modified pinmux.
hexdump of the device tree node:
root@colibri-imx6:~# hexdump -C /proc/device-tree/soc/aips-bus@02000000/iomuxc@020e0000/ipu1/ipu1grp-lcd/fsl,pins
00000000 00 00 00 9c 00 00 03 b0 00 00 00 00 00 00 00 00 |................|
00000010 00 00 00 00 00 00 00 08 00 00 00 a0 00 00 03 b4 |................|
00000020 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 08 |................|
00000030 00 00 00 a4 00 00 03 b8 00 00 00 00 00 00 00 00 |................|
00000040 00 00 00 00 00 00 00 08 00 00 00 a8 00 00 03 bc |................|
00000050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 08 |................|
00000060 00 00 00 b0 00 00 03 c4 00 00 00 00 00 00 00 00 |................|
00000070 00 00 00 00 00 00 00 08 00 00 00 b4 00 00 03 c8 |................|
00000080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 08 |................|
00000090 00 00 00 e0 00 00 03 f4 00 00 00 00 00 00 00 00 |................|
000000a0 00 00 00 00 00 00 00 08 00 00 00 f4 00 00 04 08 |................|
000000b0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 08 |................|
000000c0 00 00 00 f8 00 00 04 0c 00 00 00 00 00 00 00 00 |................|
000000d0 00 00 00 00 00 00 00 08 00 00 00 fc 00 00 04 10 |................|
000000e0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 08 |................|
000000f0 00 00 01 00 00 00 04 14 00 00 00 00 00 00 00 00 |................|
00000100 00 00 00 00 00 00 00 08 00 00 01 04 00 00 04 18 |................|
00000110 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 08 |................|
00000120 00 00 01 08 00 00 04 1c 00 00 00 00 00 00 00 00 |................|
00000130 00 00 00 00 00 00 00 08 00 00 01 0c 00 00 04 20 |............... |
00000140 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 08 |................|
00000150 00 00 00 b8 00 00 03 cc 00 00 00 00 00 00 00 00 |................|
00000160 00 00 00 00 00 00 00 08 00 00 00 bc 00 00 03 d0 |................|
00000170 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 08 |................|
00000180 00 00 00 c0 00 00 03 d4 00 00 00 00 00 00 00 00 |................|
00000190 00 00 00 00 00 00 00 08 00 00 00 c4 00 00 03 d8 |................|
000001a0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 08 |................|
000001b0 00 00 00 c8 00 00 03 dc 00 00 00 00 00 00 00 00 |................|
000001c0 00 00 00 00 00 00 00 08 00 00 00 cc 00 00 03 e0 |................|
000001d0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 08 |................|
000001e0 00 00 00 d0 00 00 03 e4 00 00 00 00 00 00 00 00 |................|
000001f0 00 00 00 00 00 00 00 08 00 00 00 d4 00 00 03 e8 |................|
00000200 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 08 |................|
00000210
EDIT: Okay I found a way. The hexdump contains 00 00 00 08
exactly 22 times, which is the amount of lines i modified and set to 0x8. So I am assuming, that I successfully modified the device tree. Just one last question: Is my described way the correct one, to reduce the EMC of the display?
