The colibri is in a Toradex Colibri Evaluation Board Rev. 3.2. I follow the instructions here: NXP i.MX and TI AM62x Recovery Mode | Toradex Developer Center and here: Toradex Easy Installer Documentation Overview | Toradex Developer Center as I did many times before. I would like to install the Toradex Easy Installer V1.7.
The console output of recovery-windows.bat seems to me like always:
config file <recovery\\\imx_usb.conf>
vid=0x15a2 pid=0x0054 file_name=mx6_usb_rom.conf
-> vid=0x1b67 pid=0x4fff file_name=mx6_usb_sdp_spl.conf
-> vid=0x1b67 pid=0x4000 file_name=mx6_usb_sdp_uboot.conf
vid=0x15a2 pid=0x0061 file_name=mx6_usb_rom.conf
vid=0x15a2 pid=0x0076 file_name=mx7_usb_rom.conf
-> vid=0x1b67 pid=0x4000 file_name=mx7_usb_sdp_uboot.conf
vid=0x15a2 pid=0x0080 file_name=mx6ull_usb_rom.conf
-> vid=0x1b67 pid=0x4000 file_name=mx6ull_usb_sdp_uboot.conf
config file <recovery\\\mx6_usb_rom.conf>
parse recovery\\\mx6_usb_rom.conf
Trying to open device vid=0x15a2 pid=0x0061
Interface 0 claimed
HAB security state: development mode (0x56787856)
== work item
filename SPL
load_size 0 bytes
load_addr 0x13f00000
dcd 0
clear_dcd 0
plug 0
jump_mode 2
jump_addr 0x00000000
== end work item
loading binary file(SPL) to 00907400, skip=0, fsize=bc00 type=aa
<<<48128, 48128 bytes>>>
succeeded (status 0x88888888)
jumping to 0x00907400
config file <recovery\\\mx6_usb_sdp_spl.conf>
parse recovery\\\mx6_usb_sdp_spl.conf
Trying to open device vid=0x1b67 pid=0x4fff
Interface 0 claimed
== work item
filename u-boot.img
load_size 0 bytes
load_addr 0x03f00001
dcd 0
clear_dcd 0
plug 0
jump_mode 2
== end work item
loading binary file(u-boot.img) to 177fffc0, skip=0, fsize=4cee0 type=aa
<<<315104, 315392 bytes>>>
jumping to 0x177fffc0
config file <recovery\\\mx6_usb_sdp_uboot.conf>
parse recovery\\\mx6_usb_sdp_uboot.conf
Trying to open device vid=0x1b67 pid=0x4000
Interface 0 claimed
== work item
filename tezi.itb
load_size 0 bytes
load_addr 0x12100000
dcd 0
clear_dcd 0
plug 0
jump_mode 0
== end work item
load_addr=12100000
loading binary file(tezi.itb) to 12100000, skip=0, fsize=13d7ee4 type=0
<<<20807396, 20807680 bytes>>>
== work item
filename boot-sdp.scr
load_size 0 bytes
load_addr 0x12000000
dcd 0
clear_dcd 0
plug 0
jump_mode 1
jump_addr 0x12000000
== end work item
load_addr=12000000
loading binary file(boot-sdp.scr) to 12000000, skip=0, fsize=12f type=aa
<<<303, 1024 bytes>>>
jumping to 0x12000000
j4 in err=0, last_trans=64 33 05 0a 00
ECHO is off.
== Successfully downloaded Tezi
Press any key to continue . . .
But there is no video output on the VGA monitor. The serial output shows this:
Industrial temperature grade DDR3 timings, 64bit bus width.
Trying to boot from USB SDP
SDP: initialize...
SDP: handle requests...
Downloading file of size 315104 to 0x177fffc0... done
Jumping to header at 0x177fffc0
Header Tag is not a IMX image
U-Boot 2016.11-1.7.0+gf4db39ecb6 (Jul 31 2018 - 11:24:02 +0000)
CPU: Freescale i.MX6DL rev1.4 at 792 MHz
Reset cause: POR
I2C: ready
DRAM: 512 MiB
PMIC: device id: 0x10, revision id: 0x21, programmed
MMC: FSL_SDHC: 0, FSL_SDHC: 1
Using default environment
In: serial_mxc
Out: serial_mxc
Err: serial_mxc
Model: Toradex Colibri iMX6 DualLite 512MB IT V1.1A, Serial# 10729564
Serial Downloader recovery mode, using sdp command
Net: using PHY at 0
FEC [PRIME]
SDP: initialize...
Downloading file of size 20807396 to 0x12100000... done
Downloading file of size 303 to 0x12000000... done
Jumping to header at 0x12000000
## Loading kernel from FIT Image at 12100000 ...
Using 'config@1' configuration
Trying 'kernel@1' kernel subimage
Description: Linux Kernel 4.1
Type: Kernel Image
Compression: uncompressed
Data Start: 0x121000dc
Data Size: 5097296 Bytes = 4.9 MiB
Architecture: ARM
OS: Linux
Load Address: 0x11000000
Entry Point: 0x11000000
Hash algo: md5
Hash value: 6b0443dad3a0fbe3e5c49198b76782e4
Verifying Hash Integrity ... md5+ OK
## Loading ramdisk from FIT Image at 12100000 ...
Trying 'ramdisk@1' ramdisk subimage
Description: SquashFS RAMdisk
Type: RAMDisk Image
Data Start: 0x125dc914
Data Size: 15663104 Bytes = 14.9 MiB
Architecture: ARM
OS: Linux
Load Address: unavailable
Entry Point: unavailable
Hash algo: md5
Hash value: 6faf2df2c2eb5ef23680728b1f26b094
Verifying Hash Integrity ... md5 error!
Bad hash value for 'hash@1' hash node in 'ramdisk@1' image node
Bad Data Hash
Ramdisk image is corrupt or invalid
Another time there is an error message “zlib decompression failed, data probably corrupt”:
SDP: initialize...
Reset cause: POR
I2C: ready
DRAM: 512 MiB
In: serial_mxc
Out: serial_mxc
Err: serial_mxc
Net: using PHY at 0
FEC [PRIME]
SDP: initialize...
Type: Kernel Image
Architecture: ARM
OS: Linux
Hash algo: md5
Type: RAMDisk Image
Architecture: ARM
OS: Linux
Hash algo: md5
## Loading fdt from FIT Image at 12100000 ...
Trying 'fdt@1' fdt subimage
Description: Colibri iMX6 Device Tree
Type: Flat Device Tree
Data Start: 0x134cc9e0
Data Size: 45520 Bytes = 44.5 KiB
Architecture: ARM
Hash algo: md5
Hash value: cd0cc8dcbf9082218ffc4498613cc416
Booting using the fdt blob at 0x134cc9e0
Loading Kernel Image ... OK
Loading Device Tree to 1fff1000, end 1ffff1cf ... OK
Starting kernel ...
[ 0.425310] imx_usb 2184000.usb: Can't register ci_hdrc platform device, err=-517
[ 0.762386] snvs-secvio 20cc000.caam-snvs: can't get snvs clock
[ 0.833519] rtc-ds1307 2-0068: hctosys: unable to read the hardware clock
Running /etc/rc.local...
Colibri-iMX6_ToradexEasyInstaller_1.7-20180731
Welcome to Toradex Easy Installer
This is a Linux based installer for Toradex modules. Currently the
installer does not have a serial console interface. You can use the
Toradex Easy Installer through any of the available display interfaces
using USB mouse/keyboard or via network using VNC. Use:
# ip addr show eth0
to display the Ethernet IP address or use USB RNDIS at IP 192.168.11.1.
/ # [ 1.885860] SQUASHFS error: zlib decompression failed, data probably corrupt
[ 1.892964] SQUASHFS error: squashfs_read_data failed to read block 0x8006e6
[ 1.900020] SQUASHFS error: Unable to read data cache entry [8006e6]
[ 1.906405] SQUASHFS error: Unable to read page, block 8006e6, size eda2
[ 1.913149] SQUASHFS error: Unable to read data cache entry [8006e6]
[ 1.919508] SQUASHFS error: Unable to read page, block 8006e6, size eda2
[ 1.926268] SQUASHFS error: Unable to read data cache entry [8006e6]
[ 1.932629] SQUASHFS error: Unable to read page, block 8006e6, size eda2
[ 2.070456] SQUASHFS error: zlib decompression failed, data probably corrupt
[ 2.077566] SQUASHFS error: squashfs_read_data failed to read block 0x8006e6
[ 2.084668] SQUASHFS error: Unable to read data cache entry [8006e6]
[ 2.091029] SQUASHFS error: Unable to read page, block 8006e6, size eda2
[ 2.097771] SQUASHFS error: Unable to read data cache entry [8006e6]
[ 2.104154] SQUASHFS error: Unable to read page, block 8006e6, size eda2
[ 2.127118] SQUASHFS error: zlib decompression failed, data probably corrupt
[ 2.134213] SQUASHFS error: squashfs_read_data failed to read block 0x784e9e
[ 2.141268] SQUASHFS error: Unable to read data cache entry [784e9e]
[ 2.147651] SQUASHFS error: Unable to read page, block 784e9e, size fd16
[ 2.154414] SQUASHFS error: Unable to read data cache entry [784e9e]
[ 2.160774] SQUASHFS error: Unable to read page, block 784e9e, size fd16
[ 2.167517] SQUASHFS error: Unable to read data cache entry [784e9e]
[ 2.173893] SQUASHFS error: Unable to read page, block 784e9e, size fd16
[ 2.180609] SQUASHFS error: Unable to read data cache entry [784e9e]
[ 2.186992] SQUASHFS error: Unable to read page, block 784e9e, size fd16
[ 2.193729] SQUASHFS error: Unable to read data cache entry [784e9e]
[ 2.200086] SQUASHFS error: Unable to read page, block 784e9e, size fd16
[ 2.206823] SQUASHFS error: Unable to read data cache entry [784e9e]
[ 2.213199] SQUASHFS error: Unable to read page, block 784e9e, size fd16
[ 2.219911] SQUASHFS error: Unable to read data cache entry [784e9e]
[ 2.226292] SQUASHFS error: Unable to read page, block 784e9e, size fd16
[ 2.233022] SQUASHFS error: Unable to read data cache entry [784e9e]
[ 2.239379] SQUASHFS error: Unable to read page, block 784e9e, size fd16
[ 2.246115] SQUASHFS error: Unable to read data cache entry [784e9e]
[ 2.252472] SQUASHFS error: Unable to read page, block 784e9e, size fd16
[ 2.259209] SQUASHFS error: Unable to read data cache entry [784e9e]
[ 2.265594] SQUASHFS error: Unable to read page, block 784e9e, size fd16
[ 2.272307] SQUASHFS error: Unable to read data cache entry [784e9e]
[ 2.278680] SQUASHFS error: Unable to read page, block 784e9e, size fd16
[ 2.285421] SQUASHFS error: Unable to read data cache entry [784e9e]
[ 2.291780] SQUASHFS error: Unable to read page, block 784e9e, size fd16
[ 2.298511] SQUASHFS error: Unable to read data cache entry [784e9e]
[ 2.304895] SQUASHFS error: Unable to read page, block 784e9e, size fd16
[ 2.311607] SQUASHFS error: Unable to read data cache entry [784e9e]
[ 2.317980] SQUASHFS error: Unable to read page, block 784e9e, size fd16
[ 2.324716] SQUASHFS error: Unable to read data cache entry [784e9e]
[ 2.331075] SQUASHFS error: Unable to read page, block 784e9e, size fd16
[ 2.337803] SQUASHFS error: Unable to read data cache entry [784e9e]
[ 2.344183] SQUASHFS error: Unable to read page, block 784e9e, size fd16
[ 2.350896] SQUASHFS error: Unable to read data cache entry [784e9e]
[ 2.357271] SQUASHFS error: Unable to read page, block 784e9e, size fd16
[ 2.364009] SQUASHFS error: Unable to read data cache entry [784e9e]
[ 2.370366] SQUASHFS error: Unable to read page, block 784e9e, size fd16
[ 2.377105] SQUASHFS error: Unable to read data cache entry [784e9e]
[ 2.383487] SQUASHFS error: Unable to read page, block 784e9e, size fd16
[ 2.390202] SQUASHFS error: Unable to read data cache entry [784e9e]
[ 2.396577] SQUASHFS error: Unable to read page, block 784e9e, size fd16
[ 2.403311] SQUASHFS error: Unable to read data cache entry [784e9e]
[ 2.409670] SQUASHFS error: Unable to read page, block 784e9e, size fd16
[ 2.416405] SQUASHFS error: Unable to read data cache entry [784e9e]
[ 2.422787] SQUASHFS error: Unable to read page, block 784e9e, size fd16
[ 2.429501] SQUASHFS error: Unable to read data cache entry [784e9e]
[ 2.435875] SQUASHFS error: Unable to read page, block 784e9e, size fd16
[ 2.442589] SQUASHFS error: Unable to read data cache entry [784e9e]
[ 2.448969] SQUASHFS error: Unable to read page, block 784e9e, size fd16
[ 2.455698] SQUASHFS error: Unable to read data cache entry [784e9e]
[ 2.462057] SQUASHFS error: Unable to read page, block 784e9e, size fd16
[ 2.468805] SQUASHFS error: Unable to read data cache entry [784e9e]
[ 2.475180] SQUASHFS error: Unable to read page, block 784e9e, size fd16
Still another time, there is VGA video output but the mouse pointer does not move (tried 2 different mice, with and without USB hub)
SDP: initialize...
Reset cause: POR
I2C: ready
DRAM: 512 MiB
In: serial_mxc
Out: serial_mxc
Err: serial_mxc
Net: using PHY at 0
FEC [PRIME]
SDP: initialize...
Type: Kernel Image
Architecture: ARM
OS: Linux
Hash algo: md5
Type: RAMDisk Image
Architecture: ARM
OS: Linux
Hash algo: md5
Architecture: ARM
Hash algo: md5
Starting kernel ...
[ 0.425312] imx_usb 2184000.usb: Can't register ci_hdrc platform device, err=-517
[ 0.762488] snvs-secvio 20cc000.caam-snvs: can't get snvs clock
[ 0.833637] rtc-ds1307 2-0068: hctosys: unable to read the hardware clock
[ 1.297482] SQUASHFS error: zlib decompression failed, [ 14.129875] Unable to handle kernel paging request at virtual address 0d561e04
[ 14.137125] pgd = 8d574000
[ 14.139846] [0d561e04] *pgd=00000000
[ 14.143461] Internal error: Oops: 805 [#1] SMP ARM
[ 14.148265] Modules linked in:
[ 14.151359] CPU: 1 PID: 172 Comm: tezi Not tainted 4.1.44-1.7.0+gf3637519a6aa #1
[ 14.158770] Hardware name: Freescale i.MX6 Quad/DualLite (Device Tree)
[ 14.165313] task: 8d1d4e40 ti: 8d560000 task.ti: 8d560000
[ 14.170741] PC is at remove_wait_queue+0x2c/0x48
[ 14.175375] LR is at remove_wait_queue+0x18/0x48
[ 14.180009] pc : [<800618ac>] lr : [<80061898>] psr: 68030093
[ 14.180009] sp : 8d561b80 ip : 00000100 fp : 8d561b94
[ 14.191501] r10: 82292480 r9 : 00000000 r8 : 00000000
[ 14.196740] r7 : 8d561cf4 r6 : 00000000 r5 : 8d35ac28 r4 : 8d561dd8
[ 14.203280] r3 : 0d561e04 r2 : 8d35ac2c r1 : 00000200 r0 : 28030013
[ 14.209824] Flags: nZCv IRQs off FIQs on Mode SVC_32 ISA ARM Segment user
[ 14.217059] Control: 10c5387d Table: 1d57404a DAC: 00000015
[ 14.222817] Process tezi (pid: 172, stack limit = 0x8d560210)
[ 14.228575] Stack: (0x8d561b80 to 0x8d562000)
[ 14.232954] 1b80: 8d561dd8 00000006 8d561bb4 8d561b98 80105380 8006188c 00000000 00000000
[ 14.241152] 1ba0: 00000000 8d561c3c 8d561f7c 8d561bb8 8010698c 80105358 808ed2dc 3b9aca00
[ 14.249348] 1bc0: 8d561f80 00000000 00000001 00017314 ffffe000 8d561be8 01a4b5b0 00000001
[ 14.257543] 1be0: 00000000 82292481 4a08b5ab 00000003 00000000 00000000 00000008 00000003
[ 14.265738] 1c00: 00000001 00000006 00000001 0000000c 00000001 0000000e 00000001 00000013
[ 14.273933] 1c20: 00000001 00000014 00000001 00000015 00000001 00000016 00000001 00000010
[ 14.282130] 1c40: 000019b4 00001d60 00000008 00000008 822916c0 00000008 8d561c84 8d561c68
[ 14.290326] 1c60: 802ffae8 8056da78 8d561cbc 00000004 822916c0 ffffffff ffffffff 8d3d7014
[ 14.298524] 1c80: 8d561cbc 802ffb78 822e4d80 8d3d6fd0 8d561cac 8d561ca0 802ffbb4 802ffb5c
[ 14.306721] 1ca0: 8d561ce4 8d561cb0 8060f9b0 802ffb88 ffffffff 00000002 8d561d14 00000080
[ 14.314919] 1cc0: 00000001 8229cd88 8d561d0c 8d561cd8 802e4b6c 80680bc4 8d561d44 00000000
[ 14.323115] 1ce0: 822b9df8 7e8544f0 00000000 00000000 8091e640 00000000 00000019 00000000
[ 14.331311] 1d00: 8d1d4e40 00000000 00000000 00000008 8da020c0 00000019 00000000 8d561cf4
[ 14.339508] 1d20: 801051d8 00000100 00000200 8d323d84 822969c0 00000019 00000000 8d561cf4
[ 14.347706] 1d40: 801051d8 00000100 00000200 8d564000 822ac780 00000019 00000000 8d561cf4
[ 14.355902] 1d60: 801051d8 00000100 00000200 822f3b40 822e3540 00000019 00000000 8d561cf4
[ 14.364099] 1d80: 801051d8 00000100 00000200 822f3bc0 82292780 00000019 00000000 8d561cf4
[ 14.372296] 1da0: 801051d8 00000100 00000200 8d22bc28 822926c0 00000019 00000000 8d561cf4
[ 14.380494] 1dc0: 801051d8 00000100 00000200 8d22bc28 82292540 00000019 00000000 8d561cf4
[ 14.388690] 1de0: 801051d8 8d35ac2c 0d561e04 8d35ac28 82292480 00000019 00000000 8d561cf4
[ 14.396887] 1e00: 801051d8 8d561de4 8d35ac2c 8d35ac28 8d561e44 8d561e20 8012df00 8012e5fc
[ 14.405084] 1e20: 8a19b220 fffff000 8a19b2c8 806f8380 8a19b220 fffff000 8a19b2c8 806f8380
[ 14.413280] 1e40: 8a22d5d8 8a19b220 8d561e6c 8d561e58 80564d1c 800ed7f8 8a19b220 fffff000
[ 14.421479] 1e60: 8d561e84 8d561e70 8010cb38 80564cf4 8a19b220 fffff000 8d561ea4 8d561e88
[ 14.429675] 1e80: 8010cc7c 8010cb04 8a22d5d8 8a19b220 8a22d628 8a22d628 8a22d5d8 8a19b220
[ 14.437871] 1ea0: 8d561ec4 8d561eb0 80107bf8 800ed7f8 8a22d5d8 8a19b220 8d561eec 8d561ec8
[ 14.446067] 1ec0: 80108720 80107ba4 8a19b220 00000000 8a22d5d8 8a22d5d8 00080040 00080060
[ 14.454265] 1ee0: 8d561f1c 8d561ef0 8d561f3c 8d561ef8 80080dcc 8050ec30 ec5f3700 000f6ce7
[ 14.462462] 1f00: 9fd0430f ffffffff 0000000e 01e813eb 80080dcc 8d561f80 05a995c0 00000000
[ 14.470659] 1f20: 8d561f48 8000fa04 8d561f7c 8d561f40 80105780 80079174 80105754 80080d84
[ 14.478855] 1f40: 05a995c0 8000fa04 0000000e 0791a9ab 00000000 147ae14d 00000006 00000008
[ 14.487051] 1f60: 01a4b5b0 8000fa04 8d560000 00000000 8d561fa4 8d561f80 80106ae8 8010659c
[ 14.495246] 1f80: 0000000e 0791a9ab 019e2308 00000008 01a4b5b0 000000a8 00000000 8d561fa8
[ 14.503444] 1fa0: 8000f860 80106a94 019e2308 00000008 01a4b5b0 00000008 0000005f 00000000
[ 14.511639] 1fc0: 019e2308 00000008 01a4b5b0 000000a8 75f3f971 00000001 00000001 0008f208
[ 14.519836] 1fe0: 00000000 7e855b10 00000000 760b1a98 88030010 01a4b5b0 1ff6c811 1ff6cc11
[ 14.528020] Backtrace:
[ 14.530523] [<80061880>] (remove_wait_queue) from [<80105380>] (poll_freewait+0x34/0xa0)
[ 14.538623] r5:00000006 r4:8d561dd8
[ 14.542267] [<8010534c>] (poll_freewait) from [<8010698c>] (do_sys_poll+0x3fc/0x49c)
[ 14.550019] r7:8d561c3c r6:00000000 r5:00000000 r4:00000000
[ 14.555774] [<80106590>] (do_sys_poll) from [<80106ae8>] (SyS_poll+0x60/0x100)
[ 14.563006] r10:00000000 r9:8d560000 r8:8000fa04 r7:01a4b5b0 r6:00000008 r5:00000006
[ 14.570938] r4:147ae14d
[ 14.573518] [<80106a88>] (SyS_poll) from [<8000f860>] (ret_fast_syscall+0x0/0x3c)
[ 14.581009] r7:000000a8 r6:01a4b5b0 r5:00000008 r4:019e2308
[ 14.586760] Code: e594200c e3a0cc01 e3a01c02 e5823004 (e5832000)
[ 14.592872] ---[ end trace 137202e3b215018b ]---
[ 99.390797] random: nonblocking pool is initialized
[ 113.056742] usb 1-1.1.1: new low-speed USB device number 5 using ci_hdrc
[ 113.181149] input: Logitech USB Laser Mouse as /devices/soc0/soc/2100000.aips-bus/2184200.usb/ci_hdrc.0/usb1/1-1/1-1.1/1-1.1.1/1-1.1.1:1.0/0003:046D:C069.0003/input/input2
[ 113.197910] hid-generic 0003:046D:C069.0003: input,hidraw0: USB HID v1.10 Mouse [Logitech USB Laser Mouse] on usb-ci_hdrc.0-1.1.1/input0
[ 125.370000] usb 1-1.1.1: USB disconnect, device number 5
[ 127.928257] usb 1-1.1: USB disconnect, device number 3
[ 127.933517] usb 1-1.1.4: USB disconnect, device number 4
[ 132.670888] usb 1-1.1: new low-speed USB device number 6 using ci_hdrc
[ 132.814569] input: Logitech USB Laser Mouse as /devices/soc0/soc/2100000.aips-bus/2184200.usb/ci_hdrc.0/usb1/1-1/1-1.1/1-1.1:1.0/0003:046D:C069.0004/input/input3
[ 132.830281] hid-generic 0003:046D:C069.0004: input,hidraw0: USB HID v1.10 Mouse [Logitech USB Laser Mouse] on usb-ci_hdrc.0-1.1/input0
[ 161.674221] usb 1-1.1: USB disconnect, device number 6
[ 184.143361] usb 1-1.1: new low-speed USB device number 7 using ci_hdrc
[ 184.282065] input: OM as /devices/soc0/soc/2100000.aips-bus/2184200.usb/ci_hdrc.0/usb1/1-1/1-1.1/1-1.1:1.0/0003:04F3:0235.0005/input/input4
[ 184.295911] hid-generic 0003:04F3:0235.0005: input,hidraw0: USB HID v1.11 Mouse [OM] on usb-ci_hdrc.0-1.1/input0
[15~[ 543.333310] usb 1-1.1: USB disconnect, device number 7
[ 567.327704] usb 1-1.3: new low-speed USB device number 8 using ci_hdrc
[ 567.470863] input: Logitech USB Laser Mouse as /devices/soc0/soc/2100000.aips-bus/2184200.usb/ci_hdrc.0/usb1/1-1/1-1.3/1-1.3:1.0/0003:046D:C069.0006/input/input5
[ 567.486594] hid-generic 0003:046D:C069.0006: input,hidraw0: USB HID v1.10 Mouse [Logitech USB Laser Mouse] on usb-ci_hdrc.0-1.3/input0
[ 638.004030] usb 1-1.3: USB disconnect, device number 8
[ 639.903645] usb 1-1.1: new low-speed USB device number 9 using ci_hdrc
[ 640.047372] input: Logitech USB Laser Mouse as /devices/soc0/soc/2100000.aips-bus/2184200.usb/ci_hdrc.0/usb1/1-1/1-1.1/1-1.1:1.0/0003:046D:C069.0007/input/input6
[ 640.063125] hid-generic 0003:046D:C069.0007: input,hidraw0: USB HID v1.10 Mouse [Logitech USB Laser Mouse] on usb-ci_hdrc.0-1.1/input0
[ 647.092169] usb 1-1.1: USB disconnect, device number 9
[ 673.146361] usb 1-1.2: new high-speed USB device number 10 using ci_hdrc
[ 673.279774] hub 1-1.2:1.0: USB hub found
[ 673.284157] hub 1-1.2:1.0: 4 ports detected
[ 673.566395] usb 1-1.2.4: new low-speed USB device number 11 using ci_hdrc
[ 715.155661] usb 1-1.2: USB disconnect, device number 10
[ 715.160998] usb 1-1.2.4: USB disconnect, device number 11
[ 719.220040] usb 1-1.1: new high-speed USB device number 12 using ci_hdrc
[ 719.353366] hub 1-1.1:1.0: USB hub found
[ 719.357753] hub 1-1.1:1.0: 4 ports detected
[ 719.640056] usb 1-1.1.4: new low-speed USB device number 13 using ci_hdrc
