I try to get my 2 Colibri modules back to their initial state (showing the toradex easy installer) in order to install a custom rootfs on them but I can’t get the board to load the proper way.
I tried on Ubuntu and WIndows 7 with differents USB cables without success.
Here is what I get from lsusb when I boot normally:
Bus 002 Device 005: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
and from dmesg:
[185241.802346] usb 2-1.2: new full-speed USB device number 6 using ehci-pci
[185241.925988] usb 2-1.2: New USB device found, idVendor=0403, idProduct=6001
[185241.925993] usb 2-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[185241.925996] usb 2-1.2: Product: FT232R USB UART
[185241.925999] usb 2-1.2: Manufacturer: FTDI
[185241.926002] usb 2-1.2: SerialNumber: A505ZEKJ
[185241.928737] ftdi_sio 2-1.2:1.0: FTDI USB Serial Device converter detected
[185241.928788] usb 2-1.2: Detected FT232RL
[185241.929267] usb 2-1.2: FTDI USB Serial Device converter now attached to ttyUSB0
After I reboot the linux (login as root → reboot), stop the bootloader (hit any key during boot delay) and enter bmode usb. Nothing change in lsusb and no new message in dmesg
Model: Toradex Colibri iMX6ULL 512MB Wi-Fi / Bluetooth IT V1.1A, Serial# 06388160
Net: FEC0
Colibri iMX6ULL # bmode usb
resetting ...
but the recovery script fails:
bemac@desktop:~/Downloads/Colibri-iMX6ULL_ToradexEasyInstaller_1.8-20181019$ sh recovery-linux.sh
Downloading Toradex Easy Installer...
no matching USB device found
Downloading Toradex Easy Installer failed...
What could be wrong?
I tried shorting the 2 pads on the Colibri module as well without a better result. IS there something else to do when using the Aster carrier board?
Thanks for your help
