Recommended heatsink for Colibri iMX6ULL
Is there a recommended heatsink to use with the Colibri iMX6ull?
Matt
Hi @madone
I am not sure why you need to have a heart sink for Colibri iMX6ULL.
You can find information and a few examples of heatsinks which could be glued to the Colibri module available in this article:
Note, adding heatsinks means mechanical stress to the module. Such heatsinks need to be applied carefully to not bend or damage the computer module. Furthermore, glued heatsinks might not be suitable for all environmental conditions, e.g. in vibrating environments.
I hope this input helps you finding a solution to your problem.
