I wanted to double check on the power supply and consumption for this SOM + Carrier Board combination. I am a novice in EE. I see Voltage supporting 5-27V , but nothing about Amps or Watts.
I had issues with a weak power supply where the Volts were good , but the Amps were just enough to get the device imaged and booted, but on any load, the device would power down. Now I have a random laptop power supply plugged into it.
12V 5A 60W , Connector: 2.1mm Plug
I have this power supply order, will this support the Apalis iMX8QM + Ixora on a full load? I figure this is 60Watts, attached devices can pull up to 30 watts… will this power supply be able to support it all?
