I wanted to reinstall the Toradex Easy Installer with a USB drive, but the Viola board with iMX7 Dual seems to have a problem with USB itself. It automatically reboots without error when using USB. After running usb start I get the following via serial output:
Colibri iMX7 # usb start
starting USB...
USB0: USB EHCI 1.00
scanning bus 0 for devices... 1 USB Device(s) found
USB1: USB EHCI 1.00
scanning bus 1 for devices...
U-Boot 2016.11-2.8.7+g5c2d46b325 (Jun 10 2020 - 17:13:37 +0000)
CPU: Freescale i.MX7D rev1.3 996 MHz (running at 792 MHz)
CPU: Extended Commercial temperature grade (-20C to 105C) at 42C
Reset cause: POR
DRAM: 512 MiB
PMIC: RN5T567 LSIVER=0x01 OTPVER=0x0d
NAND: 512 MiB
MMC: FSL_SDHC: 0
Video: 640x480x18
In: serial
Out: serial
Err: serial
Model: Toradex Colibri iMX7 Dual 512MB V1.1D, Serial# 06437741
Net: FEC0
Colibri iMX7 #
It happens every time when a USB device is attached (drive, keyboard,…) and even sometimes when nothing is attached and I run “usb start”. Any idea why this can happen or how I can get additional error messages? Can this be a power problem? (I use 5V, 3A power adapter, idle measuring 5.13V)
