I have an iMX8QM I tried to flash a custom Yocto image (.tar) with ToradexEasyInstaller.
I enter the recovery mode well by hardware and the easy installer files start to load and writing my image.
It crashed in the end since ther was not a imx-boot file in my .tar.
I restarted the board in recovery mode and ToradexEasyInstaller does not start beacuse of this error: Reading Config Block failed.
I attached a picture of the issue.
How can I recover my SOM?
I encountered another issue.
I was trying to change some u-boot parameters and then i tried to restore everything with EasyInstaller.
During ToradexEasyInstaller launching I facing up this problem:
U-Boot 2018.03-toradex_imx_v2018.03_4.14.98_2.3.0_bringup+g553fb1fa86 (Nov 02 2020 - 09:44:18 +0000)
CPU: Freescale i.MX8QM revB A53 at 1200 MHz at 55C
DRAM: 4 GiB
No panel detected: default to IT6263
lvds2hdmi_setup: No bus 6
Display: IT6263 (1280x720)
In: serial
Out: serial
Err: serial
Model: Toradex Apalis iMX8 QuadMax 4GB Wi-Fi / BT IT V1.1B, Serial# 06804968
BuildInfo:
- SCFW b929edfe, SECO-FW 27167ff2, IMX-MKIMAGE d7f9440d, ATF bb209a0
- U-Boot 2018.03-toradex_imx_v2018.03_4.14.98_2.3.0_bringup+g553fb1fa86
Detect USB boot. Will enter fastboot mode!
Net: eth0: ethernet@5b040000
Fastboot: Normal
Boot from USB for uuu
Starting download of 2246 bytes
downloading of 2246 bytes finished
Starting download of 106496 bytes
downloading of 106496 bytes finished
Starting download of 37481764 bytes
downloading of 37481764 bytes finished
## Executing script at 82e00000
Loading hdp firmware from 0x0000000082fe0000 offset 0x0000000000002000
Loading hdp firmware Complete
## Loading kernel from FIT Image at 83000000 ...
Could not find configuration node
ERROR: can't get kernel image!
this could be an artifact of using an older version of Toradex Easy Installer.
We recommend downloading the latest version. If you follow the link below, you will see a section marked as “Beta Release” holding files for version 2.0b7 of Toradex Easy Installer.
Did you install Toradex Easy Installer onto your module or are you booting from an SD-Card?
In the meantime you could try to reset your environment by typing the command “env default -a”.
