Read-only-rootfs writable
Hi
I am trying to create an image with a read only file system based on your yocto/openembedded guide.
I have built core-image-minimal for MACHINE = "colibri-imx6" and added EXTRA_IMAGE_FEATURES += "read-only-fs" to local.conf. However when booting the resulting image (installed via the Toradex Easy Installer) it isn’t read-only, I can still create files anywhere (everywhere I tried at least). As far as I can tell read-only-rootfs has made no difference.
The environment is set up according to OpenEmbedded (core) - Toradex System/Computer on Modules using Ubuntu 18.04.
Any ideas?
Moritz
Hello @LVTTL ,
Greetings from Toradex!
This question has been already discussed in our community forum a couple of times. I will link them below and please kindly have a look if they are relevant to your situation.
Janani
Hello @saijanani.tx
I have seen these 2, but couldn’t find an answer. I have tried core-image-minimal and console-tdx-image, no LXDE in sight as far as I can tell. The build runs successfully, no indication that something might not work with the read-only-fs. I just end up with a root fs that is still writable.
Kind Regargs
Moritz
Dear @LVTTL ,
Thanks again for your update, I only recently noticed that you have included EXTRA_IMAGE_FEATURES += "read-only-fs" instead of read-only-rootfs.
There exists no flag named “read-only-fs”.
Was it a typo on the question or perhaps it could be the reason for the writable rootfs?
Janani.
Hello @saijanani.tx ,
Oops, that was a mistake typing this up. I use read-only-rootfs. I also built the same image (that sets EXTRA_IMAGE_FEATURES_append = " read-only-rootfs") for a different machine and it works there.
Kind Regards
Moritz
I have just noticed something:
It seemsro is passed to the kernel, but it seems to ignore it.
cat /proc/cmdline yields:
galcore.contiguousSize=50331648 user_debug=30 ip=off root=/dev/mmcblk0p2 ro rootfstype=ext4 rootwait fec_mac=00:14:2d:4c:bd:48 consoleblank=0 no_console_suspend=1 console=tty1 console=ttymxc0,115200n8 video=mxcfb0:dev=lcd,640x480M@60,if=RGB666 video=mxcfb1:off fbmem=8M
This time I built using the image using BSP 2.8 for a custom machine based on the colibri-imx6. The only differences being that the custom machine sets a custom device tree and selects linux-toradex-rt as the default kernel. This image however is based on the non-RT kernel (overidden in local.conf), since we had issues with the RT kernel.
Kind regards
Moritz
Hello @LVTTL ,
Thank you for your patience. We have been able to reproduce the same issue at our side and we are currently looking into why it happens and what could be a possible workaround.
We will keep you updated on the developments promptly.
Thank you again for your understanding.
Janani
Hi @saijanani.tx
No worries, I’m glad we’re getting to the bottom of this.
Any idea when a workaround might be ready?
Kind Regards
Moritz
No, initially the root file system always gets mounted read-only and systemd will subsequently re-mount it read/write. To avoid this I believe fstab needs adjusting as well. Did you do that?
Hi @LVTTL
As @marcel.tx pointed out, you need to adapt the file /etc/fstab.
Change the first line to this and you will get a read-only file system:
/dev/root            /                    auto       noatime,ro            1  0
We will also investigate why this is not set by the option EXTRA_IMAGE_FEATURES_append = " read-only-rootfs".
BTW: noatime does not make any sense together with ro (;-p).
Hi @jaski.tx
Thanks! This works.
For anyone interested I have created a .bbappend that patches fstab to mount root as read-only.
Note that this makes all images read-only.
Link here: https://github.com/zechenturm/meta-ntb/tree/master/meta-ntb-toradex/recipes-core/base-files
@marcel.tx Fair point :stuck_out_tongue:
Kind Regards
Moritz
Hi @LVTTL
@marcel.tx: Thanks for your Input.
