Read-only-rootfs image using yocto for Apalis IMX6Q
I am trying to build a read-only-rootfs for Apalis IMX6Q using yocto.
So I started with the meta-readonly-rootfs-overlay layer added it to the yocto build.
And followed the instructions in the Readme.
When I tried the image the kernel boots up but gets stuck at init. I traced the error to the initscript line number 179 . Where it has to move the current mounted filesystems to the new read-write filesystem.
I am unable to debug it further.
I think my approach might be wrong. Please can you help me point to good reads that can help me get a good approach to solve this problem
What exact hardware (module and carrier board) and Software versions of things are you talking about?
