Hello everyone,
I have divided the iMX7D eMMC in multiple partitions as follows:
- p1 → Kernel / device tree partition (as default)
- p2 → Root FS (as default)
- p3 → Root FS 2 (used for FS update)
- p4 → Flags (used for FS update)
- p5 → Data partition
I would like the root file system to be mounted as read-only and use p5 partition as the only RW partition for storage purpose.
I am compiling the “console-tdx-image” with the following mods in local.conf (as suggested here Unable to mount file filesystem as read only - Technical Support - Toradex Community).
EXTRA_IMAGE_FEATURES = "debug-tweaks tools-debug eclipse-debug package-management read-only-rootfs"
DISTRO_EXTRA_RDEPENDS_remove = " angstrom-libc-fixup-hack"
The compile ends with no errors, but when I install the new image on my module, the filesystem is still mounted in RW. (I also tried a complete new image build).
I have analyzed the kernel boot arguments passed by u-boot and they seem ok:
emmcargs ip=off root=/dev/mmcblk0p2 ro rootfstype=ext4 rootwait
The only working solution I found was to modify the /etc/fstab file in Yocto like this:
/dev/root / auto ro,noatime 1 1
proc /proc proc defaults 0 0
devpts /dev/pts devpts mode=0620,gid=5 0 0
usbdevfs /proc/bus/usb usbdevfs noauto 0 0
tmpfs /run tmpfs mode=0755,nodev,nosuid,strictatime 0 0
tmpfs /var/volatile tmpfs defaults 0 0
Is it the correct way? Why the boot argument “ro” is uninfluent?
I’m working with BSP v2.8.
Thank you in advance for your help.
Luca
