Is message buffer for debug messages really possible only for Colibri modules and not for Apalis T30 modules? (Can’t test the Colibri Debug Message Logger, because I use WinCE2013)
This feature is not available currently for all Tegra modules (not only Apalis, also Colibri), it is only available for the PXA family currently. Alternatively you can enable the debug output and log the output with an external tool.
Okay. Idea was to add the debug output to the our own logs. But then it doesn’t works. Thank you.
