I did a yocto build (morty) (core-image-minimal) using meta-toradex-nxp layers. The kernel used is:
Linux apalis-imx6 4.1.44-2.7.4+gb1555bf
The only difference from the toradex defconfig is:
+ CONFIG_POWER_RESET
+ CONFIG_POWER_RESET_GPIO
+ CONFIG_LOCALVERSION
- CONFIG_MXC_GPU_VIV
All layers comes from the morty branches.
My problem is that when I boot, the boot time is about:
Startup finished in 3.057s (kernel) + 1min 9.620s (userspace) = 1min 12.677s
which is way too long. I’m using connman for the network and rauc. And both systemd services are blocked for about 1min. After the 1min has passed, I can see in the console:
[ 72.579956] random: nonblocking pool is initialized
[ 72.773527] fec 2188000.ethernet eth0: Freescale FEC PHY driver [Micrel KSZ9031 Gigabit PHY] (mii_bus:phy_addr=2188000.ethernet:07, irq=70)
[ 72.786366] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 75.837360] fec 2188000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 75.845422] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
The random pool is finaly initialized, and thus connman and rauc are unblocked and the ethernet link is up.
I was not sure at first if the problem is related to the random pool. But after some more digging I can now say that the problem is indeed caused by the random pool that is being init after a very long time. I did some debugging and found out that the connmand (and rauc too) process is linked to libgnutls, which upon initialization call the kernel random() syscall, and because it’s not initialized yet, just blocks.
Gdb trace:
(gdb) bt
#0 0x76a93dbc in syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
#1 0x768be378 in _rnd_get_system_entropy_getrandom (flags=0, buflen=<optimized out>, buf=<optimized out>)
at /usr/src/debug/gnutls/3.5.3-r0/gnutls-3.5.3/lib/nettle/rnd-linux.c:80
#2 0x768be378 in _rnd_get_system_entropy_getrandom (_rnd=<optimized out>, size=<optimized out>)
at /usr/src/debug/gnutls/3.5.3-r0/gnutls-3.5.3/lib/nettle/rnd-linux.c:98
#3 0x768bb3dc in do_device_source (init=init@entry=1, event=event@entry=0x7efffccc, ctx=0x768f5be0 <rnd_ctx>)
at /usr/src/debug/gnutls/3.5.3-r0/gnutls-3.5.3/lib/nettle/rnd.c:132
#4 0x768bb544 in wrap_nettle_rnd_init (ctx=<optimized out>) at /usr/src/debug/gnutls/3.5.3-r0/gnutls-3.5.3/lib/nettle/rnd.c:234
#5 0x76809964 in _gnutls_rnd_init () at /usr/src/debug/gnutls/3.5.3-r0/gnutls-3.5.3/lib/random.c:49
#6 0x767fbd60 in _gnutls_global_init (constructor=constructor@entry=1) at /usr/src/debug/gnutls/3.5.3-r0/gnutls-3.5.3/lib/global.c:307
#7 0x767d48bc in lib_init () at /usr/src/debug/gnutls/3.5.3-r0/gnutls-3.5.3/lib/global.c:504
#8 0x76fdf34c in call_init (l=<optimized out>, argc=argc@entry=1, argv=argv@entry=0x7efffdd4, env=env@entry=0x7efffddc)
at /usr/src/debug/glibc/2.24-r0/git/elf/dl-init.c:72
#9 0x76fdf4a8 in _dl_init (env=<optimized out>, argv=<optimized out>, argc=<optimized out>, l=<optimized out>)
at /usr/src/debug/glibc/2.24-r0/git/elf/dl-init.c:30
#10 0x76fdf4a8 in _dl_init (main_map=0x76fff958, argc=1, argv=0x7efffdd4, env=0x7efffddc)
at /usr/src/debug/glibc/2.24-r0/git/elf/dl-init.c:120
#11 0x76fcfac4 in _dl_start_user () at /lib/ld-linux-armhf.so.3
(gdb)
The question now is why is the random pool taking so long to fill? If I try the image from toradex (lxde image) with exact same kernel I don’t have this problem. I also checked and the defconfig contains all the CAAM options to enable the Random-number generator from this hw module.
Has anyone an idea about this problem?
Thanks,
