R/W access permissions to torizon user/containers on auto-mounted USB drive
Dear Developer Community,
in TorizonCore 5.1.0 on Colibri iMX8X, USB drives are automatically mounted to a new folder with the same volume name under /media (/var/rootdirs/media/) with R/W permission restricted to root user, the torizon user intended to be used by the app containers is not allowed to write in the volume by default.
I have not found the options to configure this automount neither in /etc/fstab nor as /etc/udev/rules.d. An automount.rules file is mentioned in other questions in the forum, but it seems no more present and I suppose it is (or was) used in other Yocto image configurations.
This is the result of the automatic mount, output of mount command:
/dev/sda1 on /disks/USB DISK type vfat (rw,nosuid,nodev,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,showexec,utf8,flush,errors=remount-ro)
How can I change system configuration to have masks allowing R/W permissions?
Thank you in advance and best regards,
ldvp
Greetings @ldvp,
You can make changes to /etc/fstab to modify the conditions of the automatic mounting.
For example this is what I use personally in my own setup for torizon user r/w permissions:
/dev/sda1 /media/usbhd auto relatime,nofail,utf8,uid=torizon,gid=torizon,umask=002 0 0
The important fields are the uid/gid setting but feel free to modify the above line for your needs.
