I have a Colibri T20 EVM V3.1A provided with SODIMM Col T20 512M V1.2A
I tried to update EVM from V2.3 to V2.8.1 BSP by means of USB stick
according to Flashing Embedded Linux to Tegra Modules
USB stick was FAT16 formatted on a Fedora 27 KDE, single partition and brand new partition table.
I decompressed Colibri-T20_LXDE-Image_2.8.1.tar.bz2
From #Colibri-T20_LXDE-Image_2.8.1 issued ./update.sh -o /run/media/venturi/0944-F91D safely.
Then I set EVM in recovery mode, inserted the USB stick and USB cable and issued safely:
./update.sh -d -r 512 -m 3 -v V1_2
Apparently EVM U-Boot refuses to deal with USB stick:
Colibri T20 # ver
U-Boot 2016.11-2.8.1+g30a1208727 (Mar 12 2018 - 14:11:45 +0100)
arm-angstrom-linux-gnueabi-gcc (GCC) 7.2.0
GNU ld (GNU Binutils) 2.29.0.20170912
Colibri T20 # run setupdate
MMC: no card present
** Bad device mmc 0 **
** Invalid partition 1 **
Waiting for Ethernet connection… unable to connect.
However if I issue:
Colibri T20 # usb reset
resetting USB…
USB0: USB EHCI 1.00
USB1: USB EHCI 1.00
USB2: USB EHCI 1.00
scanning bus 0 for devices… 1 USB Device(s) found
scanning bus 1 for devices…
Warning: asix_eth MAC addresses don’t match:
Address in SROM is 00:0e:c6:87:72:01
Address in environment is 00:14:2d:00:00:00
2 USB Device(s) found
scanning bus 2 for devices… 3 USB Device(s) found
If I issue:
Colibri T20 # fatls usb 0:1
If I issue:
Colibri T20 # fatls usb 0:0
colibri_t20/
710 flash_blk.img
444 flash_eth.img
307 flash_mmc.img
3 file(s), 1 dir(s)
If I issue:
Colibri T20 # usb info
3: Mass Storage, USB Revision 2.0
CBM USB2.0 201351001DFE8702
Class: (from Interface) Mass Storage
PacketSize: 64 Configurations: 1
Vendor: 0x0204 Product 0x6025 Version 1.0
Configuration: 1
Interfaces: 1 Bus Powered 100mA
Interface: 0
Alternate Setting 0, Endpoints: 2
Class Mass Storage, Transp. SCSI, Bulk only
Endpoint 1 Out Bulk MaxPacket 512
Endpoint 1 In Bulk MaxPacket 512
Colibri T20 # usb tree
USB device tree:
1 Hub (480 Mb/s, 0mA)
u-boot EHCI Host Controller
|±2 Vendor specific (480 Mb/s, 4mA)
ASIX Elec. Corp. AX88772B 000001
|±2 Hub (480 Mb/s, 2mA)
|±3 Mass Storage (480 Mb/s, 100mA)
1)How could I solve such problem ?
N.B. differently from the guide:
2)I did not issue the nand.erase chip command: is this strictly necessary ?
Infact at present I would like to save and test the V2.3 U-boot with V2.81 kernel and Root File system.
3)I did not issue the cfgblock create command: is this strictly necessary ? What IT version mean ? Is y
actually the right answer ? (else where I found N).
4)Moreover, what is the meaning and solution for the ETH problem ?
Thanks in advance for your attention.
