Hi All
I have problems with toolchain configuration. Please read text (with images)
I use Apalis imx.6 quad with ixora base board.
I have read al tutorials:
Tanks!!
Hi All
Tanks!!
Hi
Could you point out the issue you are seeing?
Max
Hi Max
Tanks for your reply. I created a new empty project and the result when trying to compile it was the following:
Makefile:780: recipe for target ‘main.o’ failed
make: *** [main.o] Error 1
11:00:34: The process “/usr/bin/make” exited with code 2.
Error while building/deploying project emptytest (kit: Toradex Qt Embedded)
When executing step “Make”
11:00:34: Elapsed time: 00:02.
Please read google drive document. Tanks.
cmake path is text in red in qtcreator. is correct?
Please help me!!
@natachahttech sorry! for delay. How exactly you built SDK ?
