Currently I’m trying to build a meta-toolchain-qt5 for the newest BSP release 2.8b3 including our layer.
Unfortunately, there are some kind of compiling errors:
ERROR: qt3d-native-5.9.6+gitAUTOINC+ea18da8361-r0 do_compile: oe_runmake failed
ERROR: qt3d-native-5.9.6+gitAUTOINC+ea18da8361-r0 do_compile: Function failed: do_compile (log file is located at /home/christian/oe-core-2.8b3/build/tmp-glibc/work/x86_64-linux/qt3d-native/5.9.6+gitAUTOINC+ea18da8361-r0/temp/log.do_compile.23194)
ERROR: Logfile of failure stored in: /home/christian/oe-core-2.8b3/build/tmp-glibc/work/x86_64-linux/qt3d-native/5.9.6+gitAUTOINC+ea18da8361-r0/temp/log.do_compile.23194
Log data follows:
| DEBUG: Executing shell function do_compile
| NOTE: make -j 8 MAKEFLAGS=-j 8 OE_QMAKE_COMPILER=gcc OE_QMAKE_CC=gcc OE_QMAKE_CXX=g++ OE_QMAKE_CFLAGS=-isystem/home/christian/oe-core-2.8b3/build/tmp-glibc/work/x86_64-linux/qt3d-native/5.9.6+gitAUTOINC+ea18da8361-r0/recipe-sysroot-native/usr/include -O2 -pipe OE_QMAKE_CXXFLAGS=-isystem/home/christian/oe-core-2.8b3/build/tmp-glibc/work/x86_64-linux/qt3d-native/5.9.6+gitAUTOINC+ea18da8361-r0/recipe-sysroot-native/usr/include -O2 -pipe OE_QMAKE_LINK=g++ OE_QMAKE_LDFLAGS=-L/home/christian/oe-core-2.8b3/build/tmp-glibc/work/x86_64-linux/qt3d-native/5.9.6+gitAUTOINC+ea18da8361-r0/recipe-sysroot-native/usr/lib -L/home/christian/oe-core-2.8b3/build/tmp-glibc/work/x86_64-linux/qt3d-native/5.9.6+gitAUTOINC+ea18da8361-r0/recipe-sysroot-native/lib -Wl,-rpath-link,/home/christian/oe-core-2.8b3/build/tmp-glibc/work/x86_64-linux/qt3d-native/5.9.6+gitAUTOINC+ea18da8361-r0/recipe-sysroot-native/usr/lib -Wl,-rpath-link,/home/christian/oe-core-2.8b3/build/tmp-glibc/work/x86_64-linux/qt3d-native/5.9.6+gitAUTOINC+ea18da8361-r0/recipe-sysroot-native/lib -Wl,-rpath,/home/christian/oe-core-2.8b3/build/tmp-glibc/work/x86_64-linux/qt3d-native/5.9.6+gitAUTOINC+ea18da8361-r0/recipe-sysroot-native/usr/lib -Wl,-rpath,/home/christian/oe-core-2.8b3/build/tmp-glibc/work/x86_64-linux/qt3d-native/5.9.6+gitAUTOINC+ea18da8361-r0/recipe-sysroot-native/lib -Wl,-O1 OE_QMAKE_AR=ar OE_QMAKE_STRIP=echo OE_QMAKE_WAYLAND_SCANNER=/home/christian/oe-core-2.8b3/build/tmp-glibc/work/x86_64-linux/qt3d-native/5.9.6+gitAUTOINC+ea18da8361-r0/recipe-sysroot-native/usr/bin/wayland-scanner OE_QMAKE_INCDIR_QT=//home/christian/oe-core-2.8b3/build/tmp-glibc/work/x86_64-linux/qt3d-native/5.9.6+gitAUTOINC+ea18da8361-r0/recipe-sysroot-native/usr/include/qt5
| cd tools/ && ( test -e Makefile || /home/christian/oe-core-2.8b3/build/tmp-glibc/work/x86_64-linux/qt3d-native/5.9.6+gitAUTOINC+ea18da8361-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/christian/oe-core-2.8b3/build/tmp-glibc/work/x86_64-linux/qt3d-native/5.9.6+gitAUTOINC+ea18da8361-r0/git/tools/tools.pro CONFIG+=tools-only QMAKE_USE_PRIVATE+=zlib ) && make -f Makefile
| make[1]: Entering directory '/home/christian/oe-core-2.8b3/build/tmp-glibc/work/x86_64-linux/qt3d-native/5.9.6+gitAUTOINC+ea18da8361-r0/build/tools'
| cd qgltf/ && ( test -e Makefile || /home/christian/oe-core-2.8b3/build/tmp-glibc/work/x86_64-linux/qt3d-native/5.9.6+gitAUTOINC+ea18da8361-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/christian/oe-core-2.8b3/build/tmp-glibc/work/x86_64-linux/qt3d-native/5.9.6+gitAUTOINC+ea18da8361-r0/git/tools/qgltf/qgltf.pro CONFIG+=tools-only QMAKE_USE_PRIVATE+=zlib ) && make -f Makefile
| make[2]: Entering directory '/home/christian/oe-core-2.8b3/build/tmp-glibc/work/x86_64-linux/qt3d-native/5.9.6+gitAUTOINC+ea18da8361-r0/build/tools/qgltf'
| linking ../../bin/qgltf
| .obj/IFCLoader.o: In function `Assimp::IFCImporter::InternReadFile(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, aiScene*, Assimp::IOSystem*)':
| IFCLoader.cpp:(.text+0x8e35): undefined reference to `Assimp::IFC::GetSchema(Assimp::STEP::EXPRESS::ConversionSchema&)'
| collect2: error: ld returned 1 exit status
| Makefile:875: recipe for target '../../bin/qgltf' failed
| make[2]: *** [../../bin/qgltf] Error 1
| make[2]: Leaving directory '/home/christian/oe-core-2.8b3/build/tmp-glibc/work/x86_64-linux/qt3d-native/5.9.6+gitAUTOINC+ea18da8361-r0/build/tools/qgltf'
| Makefile:44: recipe for target 'sub-qgltf-make_first' failed
| make[1]: *** [sub-qgltf-make_first] Error 2
| make[1]: Leaving directory '/home/christian/oe-core-2.8b3/build/tmp-glibc/work/x86_64-linux/qt3d-native/5.9.6+gitAUTOINC+ea18da8361-r0/build/tools'
| Makefile:44: recipe for target 'sub-tools-make_first' failed
| make: *** [sub-tools-make_first] Error 2
| ERROR: oe_runmake failed
| ERROR: Function failed: do_compile (log file is located at /home/christian/oe-core-2.8b3/build/tmp-glibc/work/x86_64-linux/qt3d-native/5.9.6+gitAUTOINC+ea18da8361-r0/temp/log.do_compile.23194)
ERROR: Task (virtual:native:/home/christian/oe-core-2.8b3/build/../layers/meta-qt5/recipes-qt/qt5/qt3d_git.bb:do_compile) failed with exit code '1'
NOTE: Tasks Summary: Attempted 3622 tasks of which 3605 didn't need to be rerun and 1 failed.
NOTE: Writing buildhistory
Any ideas?
