I am having a trouble to compile the application on the Qt creater.
Embedded Linux Image and SDK were build with no errors and all environment settings done as per the instruction from Toradex website. However, when I compile the empty Qt widget application, the following errors occur.
10:35:19: Running steps for project test...
10:35:19: Starting: "/usr/local/oecore-x86_64/sysroots/x86_64-angstromsdk-linux/usr/bin/qt5/qmake" /home/brian/Smartek/workspace/test/test.pro -spec /usr/local/oecore-x86_64/sysroots/armv7at2hf-neon-angstrom-linux-gnueabi/usr/lib/qt5/mkspecs/linux-oe-g++ CONFIG+=debug CONFIG+=qml_debug
10:35:19: The process "/usr/local/oecore-x86_64/sysroots/x86_64-angstromsdk-linux/usr/bin/qt5/qmake" exited normally.
10:35:19: Starting: "/usr/bin/make" qmake_all
make: Nothing to be done for 'qmake_all'.
10:35:19: The process "/usr/bin/make" exited normally.
/usr/local/oecore-x86_64/sysroots/x86_64-angstromsdk-linux/usr/bin/qt5/uic ../test/mainwindow.ui -o ui_mainwindow.h
c -pipe -g -Wall -W -D_REENTRANT -fPIC -DQT_DEPRECATED_WARNINGS -DQT_QML_DEBUG -DQT_WIDGETS_LIB -DQT_GUI_LIB -DQT_CORE_LIB -I../test -I. -I/usr/local/oecore-x86_64/sysroots/armv7at2hf-neon-angstrom-linux-gnueabi/usr/include/qt5 -I/usr/local/oecore-x86_64/sysroots/armv7at2hf-neon-angstrom-linux-gnueabi/usr/include/qt5/QtWidgets -I/usr/local/oecore-x86_64/sysroots/armv7at2hf-neon-angstrom-linux-gnueabi/usr/include/qt5/QtGui -I/usr/local/oecore-x86_64/sysroots/armv7at2hf-neon-angstrom-linux-gnueabi/usr/include/qt5/QtCore -I. -I. -I/usr/local/oecore-x86_64/sysroots/armv7at2hf-neon-angstrom-linux-gnueabi/usr/lib/qt5/mkspecs/linux-oe-g++ -o main.o ../test/main.cpp
Makefile:789: recipe for target 'main.o' failed
c -pipe -g -Wall -W -D_REENTRANT -fPIC -DQT_DEPRECATED_WARNINGS -DQT_QML_DEBUG -DQT_WIDGETS_LIB -DQT_GUI_LIB -DQT_CORE_LIB -I../test -I. -I/usr/local/oecore-x86_64/sysroots/armv7at2hf-neon-angstrom-linux-gnueabi/usr/include/qt5 -I/usr/local/oecore-x86_64/sysroots/armv7at2hf-neon-angstrom-linux-gnueabi/usr/include/qt5/QtWidgets -I/usr/local/oecore-x86_64/sysroots/armv7at2hf-neon-angstrom-linux-gnueabi/usr/include/qt5/QtGui -I/usr/local/oecore-x86_64/sysroots/armv7at2hf-neon-angstrom-linux-gnueabi/usr/include/qt5/QtCore -I. -I. -I/usr/local/oecore-x86_64/sysroots/armv7at2hf-neon-angstrom-linux-gnueabi/usr/lib/qt5/mkspecs/linux-oe-g++ -o mainwindow.o ../test/mainwindow.cpp
Makefile:893: recipe for target 'mainwindow.o' failed
/usr/local/oecore-x86_64/sysroots/x86_64-angstromsdk-linux/usr/bin/qt5/moc -DQT_DEPRECATED_WARNINGS -DQT_QML_DEBUG -DQT_WIDGETS_LIB -DQT_GUI_LIB -DQT_CORE_LIB -I/usr/local/oecore-x86_64/sysroots/armv7at2hf-neon-angstrom-linux-gnueabi/usr/lib/qt5/mkspecs/linux-oe-g++ -I/home/brian/Smartek/workspace/test -I/usr/local/oecore-x86_64/sysroots/armv7at2hf-neon-angstrom-linux-gnueabi/usr/include/qt5 -I/usr/local/oecore-x86_64/sysroots/armv7at2hf-neon-angstrom-linux-gnueabi/usr/include/qt5/QtWidgets -I/usr/local/oecore-x86_64/sysroots/armv7at2hf-neon-angstrom-linux-gnueabi/usr/include/qt5/QtGui -I/usr/local/oecore-x86_64/sysroots/armv7at2hf-neon-angstrom-linux-gnueabi/usr/include/qt5/QtCore -I. -I/usr/include/c++/5 -I/usr/include/x86_64-linux-gnu/c++/5 -I/usr/include/c++/5/backward -I/usr/lib/gcc/x86_64-linux-gnu/5/include -I/usr/local/include -I/usr/lib/gcc/x86_64-linux-gnu/5/include-fixed -I/usr/include/x86_64-linux-gnu -I/usr/include ../test/mainwindow.h -o moc_mainwindow.cpp
make: c: Command not found
make: [main.o] Error 127 (ignored)
make: [mainwindow.o] Error 127 (ignored)
c -pipe -g -Wall -W -D_REENTRANT -fPIC -DQT_DEPRECATED_WARNINGS -DQT_QML_DEBUG -DQT_WIDGETS_LIB -DQT_GUI_LIB -DQT_CORE_LIB -I../test -I. -I/usr/local/oecore-x86_64/sysroots/armv7at2hf-neon-angstrom-linux-gnueabi/usr/include/qt5 -I/usr/local/oecore-x86_64/sysroots/armv7at2hf-neon-angstrom-linux-gnueabi/usr/include/qt5/QtWidgets -I/usr/local/oecore-x86_64/sysroots/armv7at2hf-neon-angstrom-linux-gnueabi/usr/include/qt5/QtGui -I/usr/local/oecore-x86_64/sysroots/armv7at2hf-neon-angstrom-linux-gnueabi/usr/include/qt5/QtCore -I. -I. -I/usr/local/oecore-x86_64/sysroots/armv7at2hf-neon-angstrom-linux-gnueabi/usr/lib/qt5/mkspecs/linux-oe-g++ -o moc_mainwindow.o moc_mainwindow.cpp
Makefile:896: recipe for target 'moc_mainwindow.o' failed
o test main.o mainwindow.o moc_mainwindow.o -L/usr/local/oecore-x86_64/sysroots/armv7at2hf-neon-angstrom-linux-gnueabi/usr/lib -lQt5Widgets -lQt5Gui -lQt5Core -lEGL -lGLESv2 -lpthread
Makefile:212: recipe for target 'test' failed
make: [moc_mainwindow.o] Error 127 (ignored)
make: o: Command not found
make: [test] Error 127 (ignored)
10:35:20: The process "/usr/bin/make" exited normally.
10:35:20: Elapsed time: 00:00.
I cannot figure out what cause those errors. Please help me get through to it.
Brian
