Qt Demo Image SD Card Detection Problem
I downloaded the Qt Demo Image from here and install it on eMMC and after Linux boot up I can’t access SD Card! It is not detected after inserting and removing!
What should I do?
What exact hardware and software versions of things are you talking about? A complete serial console boot log as a textual file may be helpful in analyzing what’s going on.
Hi @marcel.tx,
Hardware Version: Apalis iMX6Q 2GB IT V1.1C
Ixora V1.0A
BootUp output
Thanks for the bootlog. How did you format the card?
Could you stop in uboot and provide the output after the following commands:
 #mmc dev 1
 #mmc info
Thanks for prompt reply,
I formatted it on Windows 10 with FAT32.
This SD Card is detecting on lxd-demos but on qt-demo It is not detecting.
The output:
Apalis iMX6 # mmc dev 0
switch to partitions #0, OK
Apalis iMX6 # mmc info
Device: FSL_SDHC
Manufacturer ID: 13
OEM: 14e
Tran Speed: 52000000
Rd Block Len: 512
MMC version 5.0
High Capacity: Yes
Capacity: 3.6 GiB
Bus Width: 8-bit
Erase Group Size: 512 KiB
HC WP Group Size: 8 MiB
User Capacity: 3.6 GiB WRREL
Boot Capacity: 16 MiB ENH
RPMB Capacity: 512 KiB ENH
Apalis iMX6 # mmc dev 1
MMC: no card present
Apalis iMX6 # mmc dev 2
mmc2 is current device
Device: FSL_SDHC
Manufacturer ID: 3
OEM: 5344
Tran Speed: 50000000
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 29.7 GiB
Bus Width: 4-bit
Erase Group Size: 512 Bytes
the later is my SD Card that has size of 32GB.
Where is this card inserted?
It looks like it is detected in U-Boot?
@marcel.tx @jaski.tx
I mean that the SD Card is OK and It is detected and I can use it when I use lxd-demo image instead qt-demo image on my board.
The problem is qt-demo image that don’t detect SD Card after boot up.
when run ls cmd I have only the following in my dev and none of then is my SD Card!
root@b2qt-apalis-imx6:~# ls /dev/ -l |grep "mmc*"
brw-rw---- 1 root disk  179,   0 Jan  1 00:00 mmcblk0
brw-rw---- 1 root disk  179,   8 Jan  1 00:00 mmcblk0boot0
brw-rw---- 1 root disk  179,  16 Jan  1 00:00 mmcblk0boot1
brw-rw---- 1 root disk  179,   1 Jan  1 00:00 mmcblk0p1
brw-rw---- 1 root disk  179,   2 Jan  1 00:00 mmcblk0p2
U-Boot?
yes it is detected in U-Boot.
How can set it to detect after boot up too.
Hi
You are using an Ixora V1.0 with the device tree for an Ixora V1.1. This explains the issues your are seeing.
For your HW version use the imx6q-apalis-ixora.dtb file for the fdt_file U-Boot environment variable.
Max
