Hello I am trying to cross compile qt-5.9 to work on Apalis tk1, I have installed SDK with default settings and I first tried by setting environment by following command
$. /usr/local/oecore-x86_64/environment-setup-armv7at2hf-neon-angstrom-linux-gnueabi
To configure qt
./configure -release \
-opensource -confirm-license \
-prefix $PWD/build \
-opengl es2 \
-device linux-apalis-g++ \
-device-option CROSS_COMPILE=/usr/local/oecore-x86_64/sysroots/x86_64-angstromsdk-linux/usr/bin/arm-angstrom-linux-gnueabi/arm-angstrom-linux-gnueabi- \
-sysroot /usr/local/oecore-x86_64/sysroots/armv7at2hf-neon-angstrom-linux-gnueabi \
-make libs \
-nomake tests \
-nomake examples
But this configure fails with following error
Creating qmake...
........................................................................................Done.
Info: creating super cache file /home/ubuntu/cross_qt/qt-everywhere-opensource-src-5.9.6/.qmake.super
ERROR: No device matching 'linux-apalis-g++'.
I also tried without setting above SDK environment with same results.
How to specify correct device in configure options for apalis tk1 or there are some other mistakes ?
Kindly give me links or documents for cross compilation steps of qt.
Thank you.
Regards akshay
