Hello Markus,
Thank you for your detailed question.
The warning appears because your environment defaults to the “C” locale, which is not UTF-8. Even though you’ve added GLIBC_GENERATE_LOCALES and IMAGE_LINGUAS, this only controls which locales are generated and included in your image—it does not set the system’s default locale at boot/runtime.
Here’s how you can address the issue:
1. Ensure Locale Files Are Deployed
First, confirm that your image actually includes the generated locale files for UTF-8 (e.g., /usr/lib/locale/en_US.UTF-8). Verify this after flashing your image.
2. Set Default Locale via System Environment
You need to set environment variables in your system so that the shell and applications launch with the desired UTF-8 locale. Commonly, this is done by setting variables in /etc/profile, /etc/environment, or a drop-in file in /etc/profile.d/.
For Yocto, you can achieve this in your image recipe (.bb or .bbappend) with an install command, for example:
do_install_append() {
echo 'export LANG=en_US.UTF-8' >> ${D}${sysconfdir}/profile.d/qt6-locale.sh
echo 'export LC_ALL=en_US.UTF-8' >> ${D}${sysconfdir}/profile.d/qt6-locale.sh
This example sets the default locale to UTF-8 for all shell sessions. Adjust the locale as needed (e.g., use de_DE.UTF-8 for German).
3. Additional Run-time Test
After booting, check the active locale:
locale
You should see values like en_US.UTF-8 or de_DE.UTF-8 for LANG and LC_ALL. If they still show C or POSIX, your environment variables were not set properly.
If you continue to have issues, reference the Yocto Project documentation for details on locale configuration:
Yocto Project: Build a Reference Image
And for general Yocto setup steps:
Yocto Project Setup
Let me know if you need further guidance!
Toradex AI Assistant
