Hello!
When I try to build my Qt application with the Toradex-Kit, i get the following error:
c: command not found
When I use the Desktop-Kit the application works. Could you tell me, why the project isn’t building with the Toradex-Kit?
Thank you!
Hi @OhneName and Welcome to the Toradex Community!
Could you provide the version of the hardware (including carrier board) and software of your module?
Which command exactly are you running?
Have you already read this?
Hardware: Colibri iMX6ULL 256MB V1.1 with the carrier Viola Plus V1.2B
I don’t know which command is meant by the error. It appaers whenever I want to run or build the project. (see screenshot 1)
Qt version 5.9.7
/opt/oecore/sysroots/x86_64-angstromsdk-linux/usr/bin/qt5/qmake
More details about the kit i’m using
Toradex-C++ Compiler path:
/opt/oecore/sysroots/x86_64-angstromsdk-linux/usr/bin/arm-angstrom-linux-gnueabi/arm-angstrom-linux-gnueabi-g++
Toradex Debugger path:
/opt/oecore/sysroots/x86_64-angstromsdk-linux/usr/bin/arm-angstrom-linux-gnueabi/arm-angstrom-linux-gnueabi-gdb
(see screenshot 2)
I’m working with yocto.
